PCV valve location
DIENASTY
  • 2008 FORD ESCAPE
  • 2.3L
  • 4 CYL
  • 100,000 MILES
Hi where is my PCV valve located? Thanks in advance
Sunday, October 19th, 2014 AT 8:41 AM
JDL
  • 16,098 POSTS
Note the picture #3 is pcv valve, the info is for 2.3L non-hybrid. The removal procedure says to remove intake manifold but you might be able to get around it. I have included the PCV for both engines. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sunday, October 19th, 2014 AT 10:40 AM
A.BURLATSCHENKO
  • 2005 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 100,000 MILES
Could you provide installation information for the p.C.V. Valve on a 1995 ford escape with the 3.0 engine. Location is not a problem but removal of vacuum line and re-installing info. Is required.
Tuesday, October 1st, 2019 AT 5:47 PM (Merged)
2005 Ford Truck Escape 4WD V6-3.0L VIN 1
POSITIVE CRANKCASE VENTILATION (PCV) VALVE
https://www.2carpros.com/forum/automotive_pictures/12900_pcvv1_1.jpg
Removal and Installation
1.Disconnect the battery ground cable.
2.Disconnect the positive crankcase ventilation (PCV) tube from the PCV valve and position the tube aside.
3.Disconnect the PCV valve electrical connector.
4.CAUTION: A new PCV valve must be installed if removed from the valve cover. Damage will occur to the locking mechanism on the PCV valve. Rotate the PCV valve counterclockwise and remove the PCV valve from the valve cover.
*Discard the PCV valve.
5.To install, reverse the removal procedure.
BABYDAWL0612
  • 2005 FORD ESCAPE
  • 4 CYL
  • 86,000 MILES
Can anyone tell me where the PCV valve is located on my 2005 Ford Escape? If you could provide a diagram or just a detailed description that would be ever so helpful. We have looked to the best of our ability for it and still no luck! Please help!
BLACKOP555
  • 10,371 POSTS
Its located in the valve cover and if you re move it it will have to be replaced with a new one as the locking mechanism will be ruined.
My diagrams arnt loading but look for a hose going from it and leading to the intake manifold.
PRIEL1LH
  • 2004 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 117,000 MILES
How do I find and replace the pcv valve on my ford.
  • 108,199 POSTS
It should be on a valve cover. Remove the rubber hose and unscrew it (like a half turn). here is a picture of it.
https://www.2carpros.com/forum/automotive_pictures/249084_8_3.jpg
