1999 Ford E Series Van Fuel Pump Reset Button Location Econoline Van
1999 FORD E-SERIES VAN
180,000 MILES
BUCKFREAKINWILD
where is the fuel pump reset button location 1999 ford econoline van?
Dec 12, 2012 at 7:12 PM
  • CAR REPAIR CONTRIBUTOR
Inertia Fuel Shut-Off Switch Behind right kick panel
Dec 12, 2012 at 7:18 PM
ANGELSWAYY
where is the fuel pump located on 1999 15 passenger ford van is there a reset button?
Apr 3, 2019 at 3:40 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi angelswayy,
FUEL PUMP SHUT-OFF SWITCH
This switch stops flow of fuel to engine after a collision. The impact does not have to be great to trigger the switch.
To reset, press White reset button on switch located on floorboard, to left and above where steering column passes through the floorboard.
© 2007 Mitchell Repair Information Co., LLC.
Page 1 of 1 MAINTENANCE INFORMATION -1999 Ford Econoline E250
MARK T.
Where is the fuel shutoff for the van located and what does it look like, I do not own the owners manual anymore.
BILLYMAC
  • 2,204 POSTS
two places it could be pass side kick panel where the passengers right foot would be or rear cargo area near back doors. it will be a black switch mounted securely it will have a red button in the center if button is up fuel off push button down fuel on billymac
