Fuse box location apparently it is supposed to be behind a panel?
2004 FORD E-SERIES VAN
215,000 MILES • V8 • 2WD • AUTOMATIC
HSAAGER1
  • 17 POSTS
Failed emission inspection and was told a fuse ( cigarette lighter perhaps ) is blown.
Can't find interior fuse box. Checked online and apparently it is supposed to be behind a panel underneath the steering wheel. But it isn't. Pulled of all lower plastic covers, even looked at the motor from the inside, but can't find an interior fuse box.
Can somebody please tell where it is ?
Nov 6, 2015 at 9:37 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
Here is a guid to help you check the fuses and the fuse panel locations and identifications in the diagrams below. Check fuse f2.26
https://www.2carpros.com/articles/how-to-check-a-car-fuseCheck out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Nov 7, 2015 at 7:11 AM
MONSTER BOMB
Electrical problem
2002 Ford E-Series Van 6 cyl Two Wheel Drive 157000 miles
can you please tell me where to find the fuse diagram? I don't have a manual
Jan 13, 2019 at 6:19 PM (Merged)
DAVE H
  • 13,384 POSTS
this diagram is for a E150 let me know which exact vehicle you have ?
https://images.2carpros.com/forum/automotive_pictures/266999_fuse_18.jpg
AJSCULLY
I cant get my blower to turn on for heat or air. I jumpered it and it works but I cant find a bad fuse. Where can I find a fuse diagram?
Oct 28, 2020 at 12:03 PM (Merged)
BLACKOP555
  • 10,386 POSTS
on the interior fusebox fuse 13 its 15 amps and under hood in the engine compartment fuse box fuse 13 and its a 50 amp fuse. here is a guide to help test the fuse with the fuse box location and identification in the diagrams below.
DUCRYDER749
Electrical problem
1988 Ford E-Series Van V8 Two Wheel Drive Automatic 170k miles
I would like to see if you know where I can get a diagram of the fuse box for my E350 moving van. Its a 460. The a/c doesn't work, but before I can concour that I need to figure out why the blower won't even turn on. Any help will be appreciated.
Oct 28, 2020 at 12:06 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse #8 (15 amp) in the fuse panel located under instrument panel to the left of steering column. if fuse is good check blower motor relay, found on right fender apron. Check out the diagrams (Below). Please let us know what happens.
DUCRYDER749
Thanks ill give it a shot and see what happens.
