Engine not running
1999 FORD CONTOUR
112,000 MILES • 4 CYL • FWD • AUTOMATIC
FREAPAH
My car has recently started stalling momentarily and then would continue running with loss of power especially when going uphill or when turning on defroster. Eventually the engine stopped running completely.
Oct 15, 2008 at 8:06 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
This seems like the fuel pump is going out which is a problem on these cars.
Here is a guide to help confirm the issue.
Oct 15, 2008 at 8:23 PM
218DIAMAN
showing codes po351,po352.replace engine coil a mouth age
Apr 7, 2020 at 12:06 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
If these codes appear than there is a coil not firing. If the coil is known good than check the fuses and fuse links, if they are blown than check for a short to ground in the ignition start / run circuit.
BLIKMIK
99 ford contour V6 DOHC
I just changed transmission range sensor and now car wont start. I'm almost 100% sure its in right. I installed with car in nuetrul and even check to see if back up lights are lite when in reverse and it is. so pretty sure it's right.
the car gets power to accersorys, like radio. but when u try and start nothing at all and radio will go dead and takes power from accersorys.
I can"t see how you'd put this thing in wrong anyways and for car not to start. had not started car since day before when i went on a longer then normal drive.
thanks for your help
I assumed it won't crank over when key is turn to cranking position if so check and test the starter motor, starter relay and ignition switch
BLIKMIK
the car doesnt do anything when turning key no clicking... nothing. radio and accs work. wipers are fast and dont stop when you try and start the car. but radio does stop working when try starting. does that seem normal?
I've tried putting the old sensor back in and same thing.
Go to this link for more info: https://www.2carpros.com/articles/car-engine-will-not-crank-over
TOM SCHLUETER
car ran rough . took to shop and they said needed fuel pump. New pump but still will not start. After trying to start for a few minutes gas starts running out of the air intake. After the pump was installed the car ran rough for a while and black smoke came out of the tail pipe but will not start any longer. Again, gas starts running out of the air intake after trying to start. Thank You for any help Tom
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure first. depending on engine it should be 30-45 or 45-60 with key onfirst is for 2.0 second for 2.5 auto parts rent gauges or take it back and have the place fix it right.
MRBROWN35
i was driving the car shut down. i tried to start it back up . it started to make a loud wineing sound. the car would not turn over. the check engine and battery light came .
RACEFAN966
  • 5,029 POSTS
What do you mean it won't turn over? Does the starter turn the engine and it won't start or does it just do nothing at all? Have you checked to see if the serpentine belt broke? Get back to me with what you know and we will see what we can figure out from there.
MRBROWN35
no when u turn the ignition it just makes a funny noise . it doesn't do nothing.
RACEFAN966
  • 5,029 POSTS
OK first have the battery checked. I would pull the battery out and take it to your local parts store and have them load test it. Let me know what you find here.
SCOOTER0369
Electrical problem
1999 Ford Contour 6 cyl Front Wheel Drive Automatic
99 ford contourthe car wont start at any random time the battery is dead. it will go 2 or 3 weeks start just fine then one morning battery is dead.ti does this for no certain amount of time then its fine again. any ideas what could be drawing the battery down. also has new battery and starter. it seems worse when cold or wet.
  • 110,190 POSTS
Have you checked for an electrical draw? Here is a how to. Check it and let me know what you find.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
NOTE: If you find a draw, remove each fuse one at a time until the draw stops.
Let me know what you find.
DJNYCROSBY
I have a 1999 Ford Contour and the oil light came on, then the car cut off. I added 2 quarts of oil. I then tried to crank the car and it sounds like it wants to turn over, but it doesn't. What could this mean?
CJ MEDEVAC
  • 11,004 POSTS
Most owners manuals suggest retracting the dipstick on a weekly basis if your engine moved very long without lubrication.
You might try turning your crankshaft by hand, to see if it is seized....you should be able to make a revolution with a wrench kinda ez....if it is not
sorry!
let me know your results
BLUERIVER329
  • 11 POSTS
are you can try checking the crank sensor that could be the promble why it wont started.
BLUERIVER329
  • 11 POSTS
are you can try the crank sensor that could be the promble so try that.
BOB2010
After starting and stopping several times in hot weather the 1999 Ford Contour will not start. Temperature gauge is in the middle but not hot. No spark, battery nothing. After sitting for 30 - 60 minutes it starts like there was no problem. There is plenty of spark, good battery, good coolant. What can be the problem.
Tired of sitting and waiting.
Fuel pump could be failing-check/monitor the fuel pressure-start here
ABSOLUTELY
Have the same problem -- have changed the starter, replaced the coil-pack/ignition module, have no trouble codes (incl. in memory; also no freeze-frame). Strange to see no answer after almost 4 weeks?!
RIVERMIKERAT
  • 6,110 POSTS
As stated above, check fuel pressure. You could be experiencing what's known as "vapor lock" where the fuel pressure is too low to overcome the heat of the engine compartment and the fuel vaporizes in the lines.
ABSOLUTELY
Rasmataz and Rivermikerat are experiencxed Ford technicians? The engine in the '99 Contour will NOT CRANK at all -- What could not cranking have to do with fuel and fuel pressure? The problem is not even one of ignition, but a starting issue (but NOT the starter). Also, obviously this is a known Contour 2.4L problem -- so where is previous experience?
RIVERMIKERAT
  • 6,110 POSTS
Yes, we're both very experienced Ford techs. But, I misread your original post. I missed the "it doesn't crank" part and presumed it cranked, but wouldn't fire.
Check starter draw. Both when it is cold, and when it gets hot. Also, when hot, verify that there is power to the starter, and that the solenoid is activating. Also check battery voltage and electrolyte level. And yes, you CAN do that on supposedly 'maintenance free' batteries.
Also, since I used to OWN a 2.4L Contour myself and never had this problem, I wouldn't consider it a 'known issue'. Just because one or two people have the issue, doesn't make it a common or known one.
KATER
I also have a 1999 Ford Contour with the same starting issue. We are fine for the first errand. We have to wait 30 to 40 minutes for the engine to cool. We put on our seatbelts so we can hear if there is a humming sound so we know the engine will start. We call this car the one trip wonder. I am soooooo sick of wainting around so we can start the car. If you try to start it too early you have to wait another 30 minutes. So I think this is a problem with this model since my husband has a 2000 Ford Ranger that starts all of the time. Do we need to change the fuel pump or filter? Please help. Thanks
LIL HANDS
The car was fine when we shut it off but when we went to start it an hour later it wouldn't start! There used to be a buzzing sound when you turned the key on but now there isn't! Do you think it is the relay or the pump? How should we proceed to fix this problem? Please help we do not have much money but really need the car!
Go to this link: https://www.2carpros.com/articles/car-cranks-but-wont-start
If its cranking over and w/n start -Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
RIVERMIKERAT
  • 6,110 POSTS
Check to see if the fuel pump is receiving power when the problem occurs. Kater, will it crank when the problems occurs, or does nothing happen when it occurs?
Absolutely, what's the verdict on power to and from the starter solenoid when the problem occurs?
SANDRA MALLORY
I had a starter put on and I have a new battery, and it still will not crank, when you turn the ignition it just click 1 time. The lights, radio, windows, everything comes on.
No crank at all/nothing/nada when key is engage to starting position
Could be the starter relay,park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
RMAVERICK
Engine Mechanical problem
1999 Ford Contour 4 cyl Automatic 115000 miles
was warming up and it sut off and won't start. checked spark, changed fuel filter used dry gas.
Do you have spark? And do you have the correct fuel pressure?
RMAVERICK
yes I have both
You got spark and fuel now its time to check the valve and ignition timing.
BTW do you have injection pulses?
RMAVERICK
I have not checked for pulses but I did spray starting fluid into the throttle body with no results. A couple of times after sitting for awhile it seemed to attempt to fire but only for a second. A friend told me to change the plugs and i DID and when I put them back in it seemed to backfire a bit but never really tried to start
Apr 7, 2020 at 12:07 PM (Merged)
MAMAWCITY
My car started having a rough idle then it got to where if I stopped at a light I had to jeep one foot on the brake and the other on the gas so ot wouldn't die. The idle got so rough the whole car would shake all over. Since the engine light was on I had it checked. The code sai the 2nd plug was misfiring and the #1 O2 was too lean. I changed the spark plugs and now the car won't even start. My husband says the timing is off. His nephew says it's the IAC sensor. Do you have any answers?
DAVE H
  • 13,384 POSTS
make sure you have the plug leads on in the correct order .. if they are not on correctly the car will not fire up ..
https://images.2carpros.com/forum/automotive_pictures/266999_fire_1.jpg
KVBUBBA
I had an overheating problem during a trip and the car stopped running. After towing it home and doing a compression test we found only 60 psi per cylinder. So we torn down the top end of the engine, removed and machined the heads, replaced head gaskets, water pump, spark plugs and all belts. After putting everything back together we retested the compression and got 120 psi in every cylinder but the car still only cranks over but doesn't start. Have verified that the plugs have fire but we're at a loss as to what to do next. Test the fuel pressure?
HELP!!
Double check the valve and ignition timing could be off 180 out start here
