2001 Dodge Ram Interior Lights Power Mirrors Work Everything Else Works That
2001 DODGE RAM
124,000 MILES
ANONYMOUS
My interior lights and my power mirrors don't work. everything else works that I know of. Oh, the underhood light doesn't work either. I have checked all fuses.
Mar 28, 2013 at 9:35 PM
NFPKIDS
  • 25 POSTS
You blew a fuse check them all even the ones that you think wouldnt be the problem cause they tend to be the issue
Mar 29, 2013 at 12:37 AM
  • CAR REPAIR CONTRIBUTOR
check all fuses with a test light to verify power
roy
Apr 21, 2013 at 6:43 AM
EYEU81
The radio, power mirrors stopped working. Fuses are OK and I can not find a relay that controls all of these. Is there one relay somewhere?
5.9 L V8, automatic, 107,000 miles
Thanks,
Rick
Aug 21, 2019 at 6:34 PM (Merged)
E40WATER12
  • 522 POSTS
Sounds to me, Either a loose ground wire, Some kind of wire has shorted out, I would just trace the wiring for cracks or corrioded wires.
SORTMEDIC
Hey Rick
Did you find a solution to your problem yet? I have the same truck (minus 3,000 miles) and my radio quit too. The fuse appears to be ok.
Mark
AFGAANSEHARLEY
Solution is : In the Fuse Box right from the steering wheel there is a fuse labeled IOD (Ignition Off Draw). It is one packed in a black cover 15 Amp Normal this one is the broken one.
Here is a guide and the mirror wiring diagrams
BRIANDODGE
Hey thank you so much for this information. I've been chasing wires and researching forever for this problem. And I've got it fixed!!! Thanks again!!!
  • 54,346 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
