Now my engine wont start why?
ADAMBARNES96
  • 1998 DODGE NEON
  • 4 CYL
  • 4WD
  • 198,000 MILES
I was going twenty five mph when I guess I bottomed out on a hole and hit the ground. It suddenly would not get any gas and the engine quit. Now it will try to crank, but will not turn over, only whir's. Could it be an emergency fuel switch, fuel filter, or god forbid the fuel pump?
Friday, August 12th, 2016 AT 5:35 PM
SATURNTECH9
  • 30,869 POSTS
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
https://youtu.be/dCjmRL3p4Cs
and
Tuesday, July 14th, 2020 AT 10:29 AM
ADAMBARNES96
I checked underneath, nothing is out of the ordinary or broken. Then I checked the fuel pump it was no good thanks for the guides I got it going again :)
CARNEMSIS
  • 1998 DODGE NEON
  • 4 CYL
  • FWD
  • 160,000 MILES
My neon cranks but is not turning over. It has never had this problem before. Im not sure if its a spark issue. It has hesitated before but but started every time. Could it be a coil issue? Distibutor? Spark plugs? Where should I start?
Thursday, April 1st, 2021 AT 2:01 PM (Merged)
JDL
  • 16,098 POSTS
Hi, if it cranks good but won't start. Have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. To check for spark, you can pull plug wire, stick known good plug/spark tester in the boot. Ground metal part of plug/tester to metal part of engine, have helper crank, watch for spark.
DAN VANSCONIS
  • 1998 DODGE NEON
  • 2.0L
  • 4 CYL
  • MANUAL
  • 210,000 MILES
I am getting fuel. I have spark, but it will roll over but not fire. What could it be?
Thursday, April 1st, 2021 AT 2:02 PM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
If you are getting fuel and you have spark, then I would suggest doing a compression test. Here is a link that will explain how to troubleshoot your situation:
Alex,
2CarPros
AJGILLIAM
  • 5 POSTS
  • 1998 DODGE NEON
  • 4 CYL
  • FWD
  • 90,000 MILES
Have posted 2 previous questions(1-15-09 and 2-10-09) and got good diagnostic answers BUT still can't get to start. To give someone an overview: engine will try to start so ck'd fuel pressure, ok. Ck'd spark and have spark on 2 & 3 cyl, no spark at 1 & 4 cyl. Replaced coil pack, no start. Checked for pulse and no pulse for 1 & 4 cyl. Ck'd wiring for opens at coil pack to pcm, ok. Replaced pcm with rebuilt pcm from internet supplier Auto Computer Exchange, still no start. Ck'd and no spark on any cylinders. Reinstalled old computer and got spark on 2 & 3 cyl. Again. Sent back rebuilt computer for exchange. In the meantime replaced crank sensor, no start. Ck'd wires for open, ok. Installed second rebuilt computer and no start, ck'd and did have spark at 2 and 3 again nothing at 1 and 4. Reposted question and got repy that related to cam sensor. Replaced cam sensor, no start. Ck'd wires ok. Also have ck'd for codes repeately and no codes present. What to do now?
Thursday, April 1st, 2021 AT 2:03 PM (Merged)
DAVE H
  • 13,383 POSTS
You seem to have replaced and checked everything else. May as well check the ASD relay and wiring. Although this supplies ground to coils and you must have ground for it to fire cylinders 2 & 3? Also check the slots on outer edge of flywheel/flexplate or on crankshaft counterweight. And the slots in cam timing sprocket or check you are getting pulse from these? CKP pulse wire is grey/black the CMP pulse wire is tan/yellow
AUTO SHUTDOWN (ASD) RELAY & FUEL PUMP RELAY
ASD relay and electric fuel pump relay are energized when ignition is on. These relays are controlled through PCM by switching a common ground circuit on and off. Following components are controlled by ASD and fuel pump relays:
Electric Fuel Pump
Fuel Injectors
Generator Field Winding
Ignition Coil(s)
HO2S Heating Element
When ignition switch is turned to RUN position, PCM energizes ASD relay and electric fuel pump relay which powers these components. If PCM does not receive a CMP and CKP sensor signal within one second of engine cranking (start-up), PCM will turn ground circuit off and de-energize ASD relay.
On Distributorless Ignition System (DIS), CMP sensor reads slots in cam timing sprocket. PCM uses this information along with information from Crankshaft Position (CKP) sensor to determine if fuel injectors and ignition coils are properly sequenced for correct cylinders.
CKP is a Hall Effect-type sensor. On some vehicles, CKP sensor is mounted on left rear side of transmission bell housing. On other vehicles, CKP sensor is mounted on right rear side of block, near cylinder head. Sensor reads slots on outer edge of flywheel/flexplate or on crankshaft counterweight. Each slot causes a pulse to be generated as it passes under CKP sensor. Signal generated provides engine speed and CKP information to PCM, which along with other input signals, determines fuel injection sequence, ignition signal and spark timing.
EJACOB
  • 1997 DODGE NEON
  • 6 CYL
  • 4WD
  • MANUAL
  • 12,920 MILES
The car won't start
Thursday, April 1st, 2021 AT 2:09 PM (Merged)
INTERNETMECHANIC
  • 700 POSTS
If your saying it won't even crank, check the starter circuit. Make sure battery has a full charge and connections are good.
If it cranks good but won't start, have a helper crank it, while you visually check for spark at the spark plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand auto stores used to loan out a fuel pressure gage, if you don't have one. To visually check for spark at the plugs, pull a spark plug wire loose, use known good plug or spark tester in the boot, ground metal part of plug/tester to metal part of engine, engine cranking, watch for spark.
Check for applicable mil codes, where possible.
BONNIELEEMUELLER
  • 1997 DODGE NEON
  • 2.0L
  • 1,600,000 MILES
Car has fuel in rail, but cannot hear fuel pump.
CARADIODOC
  • 33,754 POSTS
The fuel pump will only run for one second when you turn on the ignition switch, then again when the engine is rotating, (cranking or running). When Chrysler fuel pumps fail, they almost always fail to start up. Once they do start up, they rarely stop while they are running. If you do not hear the hum of the pump for that one second when you turn on the ignition switch, you can often get them started by banging on the bottom of the gas tank. If that works, it can be expected to stay running until you stop the engine. The problem may not occur again for weeks or months, but it will gradually get worse over time. Sometimes this only works when you bang on the gas tank while a helper is cranking the engine.
DANIEL EMERSON
  • 1997 DODGE NEON
  • 4 CYL
  • FWD
  • 89,000 MILES
After changing the water pump and reassembling everything. I could not get the motor to start. I was later told that the car had stalled and shut off.
But was left for me to fix. I have changed every thing the shop manual says could be defective I.E. Plugs, S/P wires, Coil, Computor (Not purchased at a dealership) and finally the Crank Position Sensor.
CPS was replaced because I got a reading of 9 volts going in but nothing coming back out.
Any ideas?
Thursday, April 1st, 2021 AT 2:10 PM (Merged)
JDL
  • 16,098 POSTS
If the vehicle cranks good but won't start, have a helper crank it while you check for spark at the plugs. If there is no spark, check for primary voltage at the coil and injectors, dark green wire orange tracer, check for voltage, engine cranking. This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
and
You might also check for codes. Cycle the key, on--off, on--off, on. By on I mean, turn the key till the dash lites come on, no further. The check engine lite starts flashing, you count the flashes to get the codes.
TRRIXTER
  • 1996 DODGE NEON
  • 4 CYL
  • FWD
  • MANUAL
  • 10,000 MILES
It had been starting, would run around 15 minutes then die like u turned the key off. After about 2 hours it would start and do the same. Now it will not start cranks- no spark I rented a high dollar scanner--it told me 1 fault code that recommended replacing the crank angle and cam angle sensors. Any good information would b helpful. Thanks---Mark
Thursday, April 1st, 2021 AT 2:12 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Unplug cam sensor see if it starts, if yes check your tining belt...test sensor this way....do not drive with sensor unplugged.
https://www.2carpros.com/forum/automotive_pictures/62217_CKP1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_CKP2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_CKP3_copy_1.gif
https://www.2carpros.com/forum/automotive_pictures/62217_CKP4_copy_1.gif
https://www.2carpros.com/forum/automotive_pictures/62217_CKP5_copy_1.gif
https://www.2carpros.com/forum/automotive_pictures/62217_CMP1_copy_1.gif
https://www.2carpros.com/forum/automotive_pictures/62217_CMP2_copy_1.gif
https://www.2carpros.com/forum/automotive_pictures/62217_CMP3_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_CMP4_1.jpg
KRAZYONE2008
  • 1995 DODGE NEON
  • 4 CYL
  • FWD
  • 120,000 MILES
Had a few problems with my 1995 dodge neon. Got the error code 54 from the car by doing the key thing. Now it wont start. We replaced the starter, water pump and the timing belt but someone said that error code 54 was most likely the camshaft position sensor. Does this sound correct?
Thursday, April 1st, 2021 AT 2:16 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Correct. Error code 54 indicates that there is no cam signal at the powertrain control module (PCM). You should have it replaced. If you are mechanically inclined and would like instructions on replacing than let me know and I will post them. Otherwise have your local garage repair it for you.
KEVEND
  • 1995 DODGE NEON
  • 4 CYL
  • FWD
  • 70,000 MILES
My friend has a 1995 neon it turns but wont start I checked the plugs and there dry after putting contact with the key check engine is on and off now could it be the ignition coil or maybe the fuel pump? Help please where stuck
OBXAUTOMEDIC
  • 3,711 POSTS
Check out the new page for your problem....
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Thursday, April 1st, 2021 AT 2:17 PM (Merged)
