Image (Click to make bigger)
SPONSORED LINKS
Wednesday, January 5th, 2011 AT 3:24 PM
JYODER
MEMBER
1 POST
2005 DODGE MAGNUM
Engine Mechanical problem
2005 Dodge Magnum V8 Two Wheel Drive Automatic
How do I get the tension out of the belt to replace it? I looked at the tensioner, but it doesn't seem to have a place to put on a breaker bar/wrench in order to reduce the belt tension.
Tuesday, January 15th, 2019 AT 6:38 PM
(Merged)
MECHANIC
Hi:
Are you sure you are looking at the tensionier and not an idler pulley. Check out the drive belt routing diagrams site on this page. Put in the car info and they will provide the info you need.
Let me know if this helps.
(Merged)
CWELLENER
MEMBER
2005 DODGE MAGNUM
41,000 MILES
Should the belt coming around the alternator be easily compressed to the point that the input side and output side touch and tensioner moves r/t v8 5.7 liter hemi
(Merged)
HMAC300
MECHANIC
Redo question.
Images (Click to make bigger)
SPONSORED LINKS
(Merged)
CWELLENER
MEMBER
Attached image (I hope) showing event. Belt segments between 1 & 7 and 7 & 6 easily displaced with two fingers until touching. Tensioner moves as a result. Is this an indication of a weak tensioner?
(Merged)
HMAC300
MECHANIC
It cold be a weak tensioner, but check the belt first it may be stretched. Check the tensioner for a worn bearing on pulley as well.
