Reverse not working?
LYIONESSA
  • 2008 DODGE DAKOTA
  • 117,000 MILES
Reverse is making a noise and not working need to know if this is a major fix?
Sunday, June 10th, 2012 AT 4:43 AM
CARADIODOC
  • 33,743 POSTS
Depends on where it's coming from. If it's in the rear differential and you have the limited slip option, there is an additive that's supposed to be used with the gear lube to prevent chatter and noise.
You may need to replace the transmission here is a video to help walk you through the steps on a similar car. The process is the same.
https://youtu.be/3vJAojsrfuU
You could have nothing more than a tight or worn universal joint but typically they will make noise going forward too.
Sunday, June 10th, 2012 AT 7:21 AM
DINE909
Thank you for this post I had this problem and had to replace the transmission cost me $834.00 all fixed I love this site. Installed it myself using the video.
Saturday, November 9th, 2019 AT 3:55 PM
ALICEG
  • 2007 DODGE DAKOTA
When I put the truck in drive or reverse, it locks up
Saturday, November 9th, 2019 AT 3:56 PM (Merged)
  • 108,192 POSTS
Check differential, check brakes, check U-joints.
ALICEG
Thanks so much, I will do that.
  • 108,192 POSTS
Let me know what you find. Can you tell me if there is a specific wheel that locks up? I need to know if the truck is 4wd too. Let me know. I may be able to better guide you.
Saturday, November 9th, 2019 AT 3:57 PM (Merged)
EDNEAZ
  • 2006 DODGE DAKOTA
  • 6 CYL
  • MANUAL
  • 47,000 MILES
I can't shift into reverse. The service shop at the Chrysler dealership says it is probably a broken synchroniser and estimates approximately $1500 for repairs. Is this a reasonable price or am I being overcharged? Also is there any factory warranty that covers this kind of problem?
DOCFIXIT
  • 18,828 POSTS
Hi
Labor on repair is @$1000 and @$300 for gear assembly so $1500 not bad. As for warranty check owners manual and contact warranty Dept.
Can you get in REV engine off then start will it back up?
Let me know
Thanks for donate
EDNEAZ
Didn't try reverse with engine off. It's in the shop now.
The warranty is a standard 3 year 36,000 mile. The shop ran the VIN on their computer and it showed the warranty has expired on this truck.
Are you referring to the warranty department from Chrysler or my local dealer?
Some research showed a lifetime warranty on the drive train, but it looks like that didn't start until 08.
Thanks,
Ed
DOCFIXIT
  • 18,828 POSTS
Apeal to Chrysler you may get some help. The milage is not that high
EDNEAZ
I've had the truck repaired and asked for the parts that were replaced. I have some photos of the parts and would like your opinion on whether this looks like normal wear. The brass bushing in the synchro ring looks ragged and the tooth in the middle of the photo on the mesh? ring is chipped.
I'll send these to Chrysler also.
Thanks.
https://www.2carpros.com/forum/automotive_pictures/440813_Reverse_syncro_1_2.jpg
https://www.2carpros.com/forum/automotive_pictures/440813_Reverse_syncro_2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/440813_Reverse_syncro_4_1.jpg
DLYONS
  • 2006 DODGE DAKOTA
  • V8
  • 4WD
  • 18,063 MILES
I have a grinding sound when I shift into reverse I took the truck into the shop and they said that the sound was normal but I dont believe that. Any help could be appreciated thanks!
EDNEAZ
[quote="Edneaz"]
Chrysler is going to refund $400 for the parts.
Thanks for your advice.
DAKOTAMAN100000
Have you got this problem fixed, and if so what was it? I am experiencing the same problem and the dealer told me the same answer. Its Normal! My truck is a 2008 Dakota SLT V8 with 13000 Still under warranty, but running out of time!
DOCFIXIT
  • 18,828 POSTS
Great news sure looks like metal fatigue cause all coffin cuts appear fine so not operator error or lack of lubricant.
CCBROOKS
  • 2002 DODGE DAKOTA
2002 Dodge Dakota 6 cyl Automatic 120000 miles
my car will Not go in reverse. It will catch sometime and sometime it will not. I have no problem with the forward gears.
  • 31,938 POSTS
Hi there, This sounds like a sticky shift valve, you really need a trans specialist to check this one out for you.
Mark (mhpautos)
WALKERDOG
  • 2002 DODGE DAKOTA
  • 153 MILES
I bought a 2002 automatic Dodge Dakota from a friend and the reverse does not work. The transmission shifts fine and I can drive forward all day long, but I can't go in reverse. When I put the truck in reverse and step on the accelerator, the engine revs. But nothing.
HMAC300
  • 48,601 POSTS
You probably have eitehr a burnt clutch or bad seal or a bad roller clutch. Take it to a trans shope and let tehm diagnose it. They can check for pressure, electrical codes, etc.
INCOLTS2000
  • 2001 DODGE DAKOTA
  • 6 CYL
  • 109,000 MILES
Truck only has mis when at a complete stop in gear or in reverse, othher then that performance seems ok as long as moving
