headlights not working
2006 DODGE CARAVAN
RACHEALCOLE
my headlights quit working, but my fog lights still work.
Oct 26, 2010 at 1:04 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
I have seen the TIPM cause this issue but fortunately is is easy to replace because it self initializes. Here is how you replace the unit. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Aug 18, 2017 at 9:35 PM
CORI_POWELL
I have a 2005 Dodge Grand Caravan and my headlights will not come on. My high beams will work if I hold them on, but won't stay on otherwise. All of the other lights come on and seem to be working fine. Any suggestions?
Jan 6, 2020 at 1:04 PM (Merged)
  • 54,350 POSTS
There is a fuse in the integrated control module located under the hood which needs to be checked. Also here is a headlight wiring diagram (below) to test for power going into and out of the module.
and
Please let us know what happens so it will help others.
Cheers, Ken
CAROL MATTERN
So I spent a lot of money to try to solve this problem. I finally found someone that realized that there is a problem with ans that have this box under the hood. There is moisture that builds up under the hood and the whole box needs to be dried out. It is a pain in the winter, but I use a hair dryer and put a tarp around it to run the dryer. It sometimes takes a few hours to dry it out. I then put heavy plastic around the top of the box and tie it down securely . It is usually good for a month or more and then you have to do it all over again. Sometimes I can tap the top of the box and get it to work for a short time before I have to dry it out. Someone told me that I should use a silicone to seal the box but I am afraid to do this, I guess.
  • 54,350 POSTS
CAn you send a pic of what you are talking about? It sounds like the TIPM is the problem which is easy to replace because it self initializes here is instructions to do so in the diagrams below.
MADMAX7709
Drivers side headlight is out so i replaced the bulb and it's still out, checked the fuses and they are fine and i also checked the wire and they are fine to so i have no idea waht the hell the problem is. Can you Help?
JDL
  • 16,098 POSTS
Did you check for voltage at the bulb circuit? The headlamp switch sends signal to bcm, bcm sends data signal to front control module, front control module controls headlamp driver. In the diagram, the top wires are voltage for high and low beam at the headlamp. Bottom wire is ground. Check applicable fuse/s for front control module. Check for applicable trouble codes.
BUBJ316
headlights wont come on at times. i have to keep turning the switch on and off till it comes on.
Jan 6, 2020 at 1:05 PM (Merged)
  • 110,190 POSTS
It sounds like the switch is going bad. Have it checked.
CHRIS ALLMENDINGER
My high beam, wipers and gauges all stopped working all of a sudden. Please help.
HMAC300
  • 48,601 POSTS
check fuses under hood and relays if accessible. then have it scanned for codes may be the TPIM module. a mechanic will need to do this.
LANCE PELAYO
my gauges do not work all the time and some time work on there own all 3 of them and when that happen my head lights do not work and my indicators ether when the gauges do not work so can you please help me and can you please tell me what the problem and how i can get it fix and what i should be looking for please
HMAC300
  • 48,601 POSTS
it may bea cluster problem needing rebuild but check grounds to body from battery and engine to battery other than that have it scanned see if something comes up
DHALDER
with car running driving lights driver side headlight does not work, but passenger side does. When switched to dashboard/parking lamp, Right headlight stops working and driver side lights up. When switch advanced to headlight again diverside headlight is off and passenger side lights up. I have changed the headlight bulbs and same pattern occurrs.
SCOYBOY
  • 10 POSTS
I think its a recall
SPANKY69NE
head lamps are not working right. the day time running lights drivers side is the only one that comes on. when i turn lights on the passenger light comes on(only) and when i switch to brights only the drivers side comes on. i have put new bulbs in an problem stays the same..
BLUELIGHTNIN6
  • 16,542 POSTS
check the wiring at both headlamp assemblies, could have damaged or loose wiring. if wiring is good there than check at the headlamp switch, most likely it is one of the headlamp assemblies wiring though.
TUKY01
my headlights stop working . but when i turn the high beams one turns on and the low beam the other head light turns on . i try everything
but when i turn the high beams one turns on and the low beam-inspect the headlamp filament, wiring connector for corrosion and also the ground
BIGGKENNY419
my 97 dodge caravan has a problem with its headlights i start the van and turn on the headlights and they will not come on but if i pull the high beam switch they come on but only if i hold the switch i know it is not a fuse any one have any ideas?
CARADIODOC
  • 34,309 POSTS
Just found the service manual. This procedure is different than what I remembered:
ACTUATOR CALIBRATION TEST
Set blower motor on High.
Set Mode position to Panel.
Open all AC outlets.
Set temperature to cold.
Press Wash and Rear Wiper buttons at the same time for five seconds until all leds flash.
All leds will turn on for five seconds.
The calibration test is running when the Rear Wiper and Intermittent leds are flashing alternately.
Acceptable result is the Rear Wiper led is the only one flashing. Press Rear Wiper to exit. At this point, the calibration and cooldown procedures can be run separately.
COOLDOWN TEST
Set the blower motor on High.
Set mode to Panel.
Set the temperature to cold.
Press Wash and AC at the same time. (See note at the end).
Then there's a note in the manual that says the test will fail if the ac evaporator is already cold. HUH? "To correct, operate system with AC OFF and the blower motor on high for three minutes prior to starting the test". That's probably why I remember putting the temperature to hot before starting this test.
Cooldown test is running when AC and Recirc. leds are flashing alternately. If they flash at the same time, the test has failed.
To abort the test, press the Rear Defogger, Recirc, and Rear Wiper buttons or cycle the ignition switch off and back on.
The manual doesn't say what to do next, but as I recall, if the test passes, only the AC led will be flashing. Press it to exit the procedure.
Note: For the Cooldown test, the manual say to "Press Wash and AC at the same time". Later, it says "Cooldown test is running when AC and Recirc leds are flashing alternately". To start the test, I think they meant press the AC and Recirc buttons, not the AC and Wash buttons. Try it both ways if you have to.
caradiodoc
CARADIODOC
  • 34,309 POSTS
Sorry, that previous comment was for a different post.
For your headlights, do you have fog lights and do they work? If they do, both of your low beam headlamp bulbs are burned out. Pulling on the dimmer switch and holding it turns on the high beams.
There are four separate fuses for the headlights. The fog lights also run off two of the fuses, so blown fuses would affect them too. It's unlikely two fuses would blow at the same time.
There are two headlamp relays. Try switching the high beam and low beam relays. If only the low beams work now, the other relay is defective.
The low beam relay is controlled by the Daytime Running Lamp Module for Canadian vehicles, or the Body Control Module for U.S. vehicles. Great! Another over-complicated, unreliable computer to perform a simple operation. Now's the time to pay up for another unnecessary computer! Let's hope it's just a relay or two bulbs.
The headlight switch sends a voltage to the Body computer; the Body computer grounds the low beam relay. From looking at the diagram, it looks like the high beam relay uses common sense and is simply grounded to the body, so the high beams should still work if the Body computer is defective.
Replacing the Body computer is not a do-it-yourself project. It is bolted to and plugged into the Junction Block above the brake pedal. Try the relays and bulbs first.
caradiodoc
REPAIRDOG2
When turning on headlights right light works.Pull multi function switch for highbeams and right goes out,leftone lights. Pull again and getleft out right on.
Nov 11, 2020 at 12:05 PM (Merged)
ZACKMAN
  • 4,202 POSTS
With a voltmeter or test light, test the headlight circuits.
1. Remove driver-side headlight socket from the headlight, and test the connector. My understanding is that at low beam, driver OFF passenger ON. At high beam, driver ON passenger OFF.
* (Test low beam) With the headlight switch at ON position, attach the positive probe to white/dark blue and the negative to black/light green wire. If you have voltage, replace the bulb.
* (Test high beam) Turn high beam ON. Positive probe to white/light green wire and negative to black/light green wire. You SHOULD have voltage.
2. Remove the passenger-side headlight socket from the headlight, and repeat test.
* (Test low beam) Headlight switch ON, attach positive probe to white/tan wire and negative probe to black/tan wire. Assuming my understanding, you SHOULD have voltage.
* (Test high beam) Turn the high beam on. Positive probe to white/gray wire and negative to black/tan wire. If you have voltage, replace the bulb.
Reason: Your headlight bulb contains 2 filaments, one for low and one for high beams. It just so happens that yours burned out the opposite way.
If you don't have voltage where you SHOULD HAVE HAD voltage, your headlight switch is defective.
Let us know.
BMRFIXIT
  • 19,053 POSTS
It sounds like the IPM has gone out here is how you can fix the problem.
JULESB
I have a 2001 Dodge Caravan, for the best part of a year I have had problems with the headlights. When I start the engine I only have the left daytime running light, when I turn the headlights on the left one goes out and the right one comes on. Both side lights work but, only the left light works on high beam. Every now and then I will have both headlights. I had a mechanic check it and he said he thinks it is the PCM--Dodge wants $800-$1000. I called a salavge yard and they said I could get one from them for approx $200, obviously used and may not work either, but I could keep exchanging until I find one that works. Any advice?
ZACKMAN
  • 4,202 POSTS
You need to replace both bulbs. Your headlight bulb is 9007 which has dual filaments. Filament A for low beam, and filament B for high beam. In your case, your driver side bulb has the filament A burned out, and your passenger side has the filament B burned out. Make sure that you don not touch the glass while replacing those bulbs.
MLESTER11
I had the same thing happen to my 2001 Caravan, 185,000 miles, 6 cyl on 11/16/08. I noticed the right side daytime running light not working. Later, driving along last night with regular headlights both on, the left regular beam suddenly winked out, the right regular stayed on. I switched to high beams, the left came on and the right went off. I thought it might be different elements in the bulbs, so I replaced them both today. The new bulbs are a little brighter, but they still do the same thing.
Is there a fuse or relay somewhere that could cause this? I can't find any blown fuses.
Thanks,
Michael
ZACKMAN
  • 4,202 POSTS
I don't see any relay or fuse controlling the headlight system, except for fog lights. Fog light operation does not affect your regular headlight or your daytime running light. Everything is controlled by Intelligent Power Module located at left side of engine compartment. If you have replaced the bad headlights with new one, and it only works one-sided, you may have to ask the dealer to check the IPM.
LARRYTRAYER
  • 5 POSTS
Need some leads on the following. Tail lights and dash lights do not work. Brake lights, head lights and turn signals work fine. Also the A/C only comes on when it is turned all the way up and it does not blow cold. Please help, it is hot in FL. Thanks!
E40WATER12
  • 522 POSTS
Ok so youre dash lights & tail lights dont work?. I would first take a look into youre fuse panel to see if any of those are blown, Then I would replace youre bulbs to see if that does anything to correct the problem. If not, Then you have to try to find what colored wires go to what bulb, Then check wiring for cracks or corroided wires, In which then have to be replaced.
Good Luck.
