Fuse panel diagrams and where are they? locations
2008 DODGE AVENGER
107,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOHNNYT86
My car wont start and i changed a relay and replace it with another one that i removed from next to it and it started but the next day it wouldn't so i need to know which would be the fuel pump relay and which one is the started it there is one. i have 4 relays. what are they for and which one is which? thank you
Jun 16, 2014 at 9:55 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
Hey Johnnyt86,
There is not a fuel pump relay because it is integrated into the TIPM here is a diagram and guide to help you troubleshoot the problem. They had problems the TIPM which will need to be replaced and programmed it will cost about $130.00
and
Mar 22, 2017 at 8:28 PM
HENTONBROWN
I have a 2000 Dodge Avenger 2.5L v-6, 150K miles that has started blowing the 30 amp fusible link. According to the Haynes manual, this fuse is connected to the starter relay.
I have replaced the link and and the car runs for a little while and the link separates again. I believe that there is a short somewhere but I don't know where.
Please Help,
Henton
Jan 25, 2021 at 7:48 PM (Merged)
CARADIODOC
  • 34,309 POSTS
After the link blows, what stops working? Does the engine still crank? If it does, the terminal on the starter relay is just a convenient tie point. Ford is famous for doing that, but your car should have plug-in relays with no provision to bolt on extra wires. For that reason, I'm guessing the link is in the starter solenoid circuit. It should not blow when the circuit is not energized.
If the link blows while driving, (not when cranking the engine), use plug-in terminals and / or clip leads to connect a headlamp bulb in place of the fuse, then wiggle and poke stuff to see if the short will occur. When it does, the bulb will go to normal, full brightness. When the short is gone, the bulb will go out. That will save the expense of constantly replacing fuses. If this is indeed the starter solenoid circuit, it will not work with the bulb installed because the bulb has too much resistance to allow enough current to pass.
A more common high current circuit to cause this problem is the radiator fan. If the link doesn't blow until the engine is warmed up, and you suspect the fan motor, bypass the fan relay and watch if the light bulb gets bright. If it does, unplug the motor and try it again. If the bulb still gets bright, there's a short in the wiring. If the bulb stays off, suspect a shorted or tight motor. If the motor tries to run, it will run slow due to the resistance of the light bulb in the circuit.
To bypass the relay, unplug it and use a jumper wire between the two terminals for the relay's contacts as shown on the drawing in the side of the cover, OR, you can pop the cover off, plug the relay back into the socket, and squeeze the contacts to turn them on.
Other things to try include rocking the car while it's in park to cause the engine to rock. This will make wiring harnesses shift position. If you can get the light bulb to stay bright, run around unplugging various connectors to see if any affect the bulb. That could help lead to the cause.
caradiodoc
