Fuel filter & fuel pump relay?
RONTOB
  • 1999 DODGE AVENGER
  • 6 CYL
  • FWD
  • 64,000 MILES
Where our they located on the car?
Sunday, May 23rd, 2010 AT 4:57 PM
https://www.2carpros.com/forum/automotive_pictures/12900_ff_13.jpg
The fuel filter is located on the frame rail, near the fuel tank.
Relay Locations Views A - H
https://www.2carpros.com/forum/automotive_pictures/12900_fpr_13.jpg
Fuel Pump Relay - Picture B
Sunday, May 23rd, 2010 AT 6:06 PM
BIGTYTY2009
  • 1996 DODGE AVENGER
  • 4 CYL
  • FWD
  • 136,133 MILES
I was wondering where te fuel pump relay switch was on a 1996 Dodge Avenger?
Tuesday, September 29th, 2020 AT 11:15 AM (Merged)
Here is a guide to help you check the relay witht he fuel pump relay in the diagrams below.
BIGTYTY2009
Ok is it on the engine side of the firewall or on the other side
I'll check on the firewall as illustrated in the diagram first
BIGTYTY2009
Ok is it easy to get to or do I have to move something to get to it cause I looked and I couldnt find it
REBRBBE
Electrical problem
1996 Dodge Avenger 6 cyl Front Wheel Drive Automatic
I'm not getting fuel from the fuel pump at all. I checked the fuel pump relay and the shut down relay on another avenger and they are good. The fuel pump relay will not close. What controls the relay. Also I don't think it's a bad crank or cam position sensor as I am getting spark at the spark pluggs.
Tuesday, September 29th, 2020 AT 11:16 AM (Merged)
RACEFAN966
  • 5,029 POSTS
Sound like a bad fuel pump. Do you have any fuel pressure? Will it fire if you spray carb clean in the throttle body? Get back to me and we go from there.
JRBURTON
  • 1995 DODGE AVENGER
  • 2.5L
  • 6 CYL
  • 200,000 MILES
No fire to my fuel pump, no fire to my injectors and no fire to my plugs. I have changed fuel pump relays and crankshaft sensor, still will not start.
CARADIODOC
  • 33,742 POSTS
The relay circuit you should be in is for the automatic shutdown, (ASD), relay. The crankshaft position sensor can cause no spark and no fuel, but the better suspect is the camshaft position sensor in the distributor. To verify you are in the right area, if you do not have access to a scanner, monitor the voltage on the feed wire from the ASD relay. That should be a black/red wire, but just look for the wire that is the same color at every injector. This is best tested with a test light. Most digital voltmeters do not respond fast enough to catch what you need to see. Back-probe that wire through the rubber seal at any connector.
You should see the test light turn on for just one second when you turn on the ignition switch, then it will turn off. You may hear the hum of the fuel pump for that one second. If you have that, the ASD relay and circuit are okay, and the engine computer has control of it. What is important is if that voltage comes back during cranking. If it does not, suspect the camshaft position sensor.
Your first step should have been to read and record any diagnostic fault codes, but be aware fault codes for the cam and crank sensors often do not set just from cranking the engine. You did not give any history leading up to a symptom or problem, but setting these fault codes often only occurs when a stalled engine is coasting to a stop. Reading fault codes is easy with a scanner, but if you do not have one, here is a link to reading them yourself:
https://www.2carpros.com/trouble_codes/obd1
Start with the Chrysler procedure. Chrysler made reading their fault codes much easier than any other manufacturer. If this does not work, you will need to follow the procedure for Mitsubishi.
