Mechanics
CYLINDERS 1 AND 4 NOT FIRING
1999 Saturn SL2 • 150,000 miles
Okay so I'm having an issue with the cylinders 1 and 4 not firing, they are on the same coil. I've switch coils and they still don't fire. I've also switched out the ignition control module, and still 1 and 4 are not firing. I am at a loss for what should be checked next. Thanks in advance.
Myself1168
May 8, 2013.
Also it is not sparking from/at the coil so its not wires or spark plugs.
AD
Myself1168
May 8, 2013.
Scan for a crank angle sensor fault check for power at the coils.
Mhpautos
May 9, 2013.
AD
