Where is the antifreeze drain plug located on a.
ANONYMOUS
  • 2000 CHRYSLER SEBRING
Where is the antifreeze drain plug located on a 2002 chrylser sebring convertible with a 2.5 liter v- 6 engine/
Wednesday, November 28th, 2012 AT 6:56 PM
CARADIODOC
  • 33,760 POSTS
Pull the lower radiator hose instead. There were a lot of problems with the radiators from that supplier. When you loosen the plug something causes the plastic seat inside to crack. That results in a slow leak of a drip about once every five seconds. The only fix for that is to replace the radiator.
Wednesday, November 28th, 2012 AT 7:20 PM
SOXX74
  • 1998 CHRYSLER SEBRING
  • 6 CYL
  • 78,464 MILES
I need to flush out my Radiator and add new Anti-freeze. Where is the Drain-plug to the Radiator? Thank you! Soxx
Monday, May 18th, 2020 AT 2:24 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The radiator is the corrugated fin, downflow type, and is cooled by electric radiator fans. Service the cooling system with high quality ethylene glycol or other aluminum compatible antifreeze coolant.
NOTE:
If the radiator draincock on Cirrus, Stratus and Sebring convertible models equipped with the 2.5L engine cannot be located, remove the right lower fog light unit from the front vehicle bumper/fascia. Then, loosen the mounting fastener and swing the horn out of the way. If necessary, unplug the wiring connectors.
Fig. 1: Typical cooling system assembly-Sebring coupe and Avenger
https://www.2carpros.com/forum/automotive_pictures/261618_0900c152800897e0_1.jpg
Thanks for using 2CarPros.com!
SOXX74
Thank you very, very much for the info on my Car (which is a very complicated instrument) and hopefully my Son can figure out, how to drain and flush my Radiator! In regards to the donation, I am very broke at the moment, but the next time I need help, I will surely show my graditute for your kind help! Thank you again. Respectfully Soxx/Marlene
TALIS31
  • 1996 CHRYSLER SEBRING
  • 6 CYL
  • 157,000 MILES
Trying to draing the cooling system, but I can't find the drain plug for my Sebring, any hints on the location? Driver or passenger side of the radiator?
Thanks!
CARADIODOC
  • 33,760 POSTS
Hi again, Talis31. Don't bother with the drain plug. Pull the lower hose instead. Something breaks in the radiator tank when the plug is unscrewed, then the rubber o-ring on the plug won't seal and you'll have a drip about every ten seconds. We had a whole pile of cars sitting at the dealership waiting for new radiators after they had cooling system services done.
As I recall, the drain is behind the right headlight housing under about a two-inch square hole, and under the horn.
Caradiodoc
TALIS31
Good thing I didn't find it then. Going to have to get it up on a lift, the way the botton hose is situated, I can't get to the clamp, it's one of those you have to get a pair of plyers on and there is no room when the car is on the ground, don't know if there will be room even on a lift.
