i can hear ac kick on in the engine but fan is not turning on. wondering if its the relay and if so where is it located
Jul 28, 2019 at 11:36 AM
(Merged)
GARYS712
MEMBER
Check fuse panel under hood on driver's side. You can also try to unhook negative terminal from battery and then hook back up after a minute or so. Things might reset then.
(Merged)
VIKTORIA
MEMBER
1 POST
what fuses should i check for my air conditioner
(Merged)
CAR REPAIR CONTRIBUTOR
the fuse is in the power disrubution center.. also check this page.
