I can hear ac kick on in the engine but fan is not turning on. Wondering if its the relay and if so where is it located
Sunday, July 28th, 2019 AT 11:36 AM
(Merged)
GARYS712
MEMBER
Check fuse panel under hood on driver's side. You can also try to unhook negative terminal from battery and then hook back up after a minute or so. Things might reset then.
(Merged)
VIKTORIA
MEMBER
1 POST
2004 CHRYSLER PACIFICA
6 CYL
2WD
AUTOMATIC
95,000 MILES
What fuses should I check for my air conditioner
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
The fuse is in the power disrubution center.. also check this page.
