Mechanics
CHEVY HEATED SEATS
2004 Chevrolet Tahoe
Electrical problem
2004 Chevy Tahoe V8 Four Wheel Drive Automatic 120000 miles
Hi, I was wondering if you had any suggestions as to why the drivers side heated seat turns itself off after a few seconds of being turned on?
Jonson
March 25, 2008.
This is a stupid question and I hope I dont insult you, but when you drive do you rest your arm and hand on your arm rest on the door? GM had a bulletin for heated seats coming on from customers bumping the button when they hit a bump with there arm resting on the arm rest. They came out with a replacement so the button sits farther in the door panel. Just an Idea for ya to consider. If you dont think that is the problem have the system check with a code scanner. Other wise I have seen those buttons stick internally causing the heated seats to come on when you hit a bump.
Rhall77
Mar 25, 2008.
Rhall77, no such thing as a stupid question, thanks for your thought but I don't have that kind of luck.
AD
Jonson
Mar 25, 2008.
AD
