2002 Chevrolet Tahoe
Engine Performance problem
2002 Chevy Tahoe V8 Two Wheel Drive Automatic 106000 miles
How do you replace a fuel pump in a 2002 Chevy Tahoe?
March 27, 2009.
For gasoline engines perform the following operations.
REMOVAL: Properly relieve the fuel system pressure.
Drain the fuel from the vehicle.
Remove or disconnect the following: Negative battery cable
Fuel tank from the vehicle
Locking ring (located on top of the fuel tank)counterclockwise
Lift the fuel pump assembly out of the tank
INSTALLATION: Install or connect the following: Fuel pump and secure with locking ring
Fuel tank to vehicle and refill
Run engine and check for fuel leaks.
FUEL TANK REMOVAL/INSTALLATION: If removing a rear tank, remove the spare tire then remove the crossmember.
Drain the fuel tank.
Remove the fuel filler pipe and remove the tank shield, if equipped.
Label and disconnect the EVAP lines and electrical connection from the fuel tank assembly.
Disconnect the fuel line from the tank.
Support the fuel tank using a suitable jack. Remove the strap bolts and the straps.
Lower the tank halfway. Be sure the fill neck does not get hung up on the chassis harness. Detach the harness clip from the crossmember.
Lower the tank enough so that the electrical connections are accessible. Detach the connections then fully lower the tank and remove it from under the vehicle.
Installation is the reverse of removal. When installing the tank, be sure to inspect all lines, hoses and electrical connections first. Repair or replace as necessary. Tighten the strap bolts to 30 ft. Lbs. (40 Nm). On rear tanks, tighten the crossmember bolts to 37 ft. Lbs. (50 Nm).
To check for leaks, refill the tank then turn the ignition ON (engine OFF) for 2 seconds. Turn the ignition OFF for 10 seconds. Turn the ignition ON again (engine OFF) and inspect the tank and lines for leaks.
Thanks for using 2CarPros. Com!
Mar 27, 2009.
