Mechanics
CHEVY FUEL PRESSURE REGULATOR
1998 Chevrolet Tahoe
Engine Mechanical problem
1998 Chevy Tahoe V8 Four Wheel Drive Automatic
where can I find the fuel pressure regulator on my tahoe
Brad beagley
February 23, 2009.
Fuel pressure regulator is located under upper intake manifold assembly.
REMOVAL: Relieve fuel system pressure. Disconnect negative battery cable. Remove upper intake manifold assembly. Remove regulator.
INSTALLATION: Reverse removal procedure for installation. Assemble regulator with vacuum tube pointing down into the snap ring retainer.
Thanks for using 2CarPros. Com!
Bluelightnin6
Feb 23, 2009.
