2CarPros - Car Questions & Answers
1997 Chevrolet Suburban Repair Question
Topics covered: Engine, Fuel pump, Spark.
Asked on December 18, 2009
1997 Chevy Suburban Will not start (suspect fuel pump)
Engine Mechanical problem
1997 Chevy Suburban V8 Four Wheel Drive Automatic 129000 miles
Hi, My wifes suburban will not start. Turns over o.k. but will not fire. I put 5 gallons of gas in it and still wouldn't start. So I suspected the fuel filter. Change it and still wouldn't start. Put a new fuel pump relay in and again wouldn't start. I no that the fuel pump is in the gas tank and will be a pain to change. Am I missing something (control module)? What should I check to verify? Thanks Steve. Also It died while she was driving.
Avatar Asked by bondo7777
Answer
Replied on December 18, 2009
No start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tiny Answered by rasmataz
68 questions asked
