FUEL FILTER?
1998 CHEVROLET SUBURBAN
225,000 MILES • V8 • 2WD • AUTOMATIC
TIM FLACK
where is the fuel filter ..i am changing the fuel pump...truck acts like it is out of gas ./should i also change the fuel line for the fuel pump? can recommend a quiet fuel pump. thank you tim
Jul 26, 2010 at 9:56 PM
  • CAR REPAIR CONTRIBUTOR
Here is a guide to help walk you through the steps of changing the fuel pump and fuel filter which is on the pump with instructions in the diagram below to help you change it out on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jul 27, 2010 at 3:36 AM
TIM FLACK
Please answer my questions as I presented them to you. The truck has 225k on it and I didnt think putting 300 into it was really an expense at all. The fuel pump has never been changed and the filter only once. No pressure test required as it acts as if it running out of gas as i drive. Start-up are as if there is gas at all. Easy to define the problem without testing.
I am seeking a quieter runnning fuel pump. BUt would like the best one also. The hoises that i referred to are only the ones from the pump itself to itys juntions. flexible hoses. . Can you recommend a desired fuel filter ?
Thank You.
Tim Falck
Jul 28, 2010 at 11:07 AM
If you owned this vehicle originally and it didn't come with the noise, I recommend only OEM parts.
Jul 28, 2010 at 3:21 PM
TIM BRYANT
The gas filter under the driver seat has two steel lines going into this can. On the end of the steel lines (both of them --they have an o-ring. I had AutoZone and O'reily's tell me that it does not need these. I afraid I do not believe them. How is right and if needed to I need to go to the dealer.
Sep 7, 2020 at 1:31 PM (Merged)
Hi Tim,
I am not sure what o-rings you are referring to. Can you get a picture and that will help explain? I am not aware of any so I would think they are correct. I attached the process and they don't mention them either.
OCEANER
Where is the fuel filter located on the gasoline engine
Sep 7, 2020 at 1:32 PM (Merged)
The fuel filter is located on the driver side under the passenger door on the inside of the frame. Here is a guide
MIKESHURTE
change fuel filter
FIXITMR
  • 9,990 POSTS
sure, bring it over with lots of beer!
FIXITMR
  • 9,990 POSTS
should be under drivers side along frame rail and a couple wrenches should do the trick.1 to hold filter nut and the other to break line loose/unscrew.
CATFISH71
Engine Performance problem
1991 Chevy Suburban Four Wheel Drive Automatic 250000 miles
i have a 6.2 litre diesel. i changed the fuel filter and mechanical fuel pump and have fuel to the pump and filter but it still wont start. what should i do
BLUELIGHTNIN6
  • 16,542 POSTS
check fuel pressure to ensure there are no restrictions. if pressure is OK then check spark at the plugs, make sure it is bright blue spark.
CATFISH71
how and where do i check the pressure. also i have glow plugs not spark plugs
BLUELIGHTNIN6
  • 16,542 POSTS
sorry didn't realize it was diesel.
test the glow plugs first
Pull the electrical connector wires off to expose access to the glow plugs. Removing one plug at a time, place the socket over the top of the glow plug and turn it counterclockwise to remove.
Clean the threads of the glow plug with solvent and a rag.
Set your voltmeter to "Ohms" (Ω) and touch the electrodes of the voltmeter to the glow plug.
Check to see if the resistance shown on the meter indicates "∞". If it does, then the plug is defective. If the glow plug shows resistance that is approximately less than 5 Ω, then the plug is not defective.
Repeat above steps for each glow plug.
CATFISH71
before i changed the fuel filter and fuel pump it was running rough
BLUELIGHTNIN6
  • 16,542 POSTS
was the check engine light coming on or staying lit? so it was running prior to replacing pump?
CATFISH71
no the check engine lite wasnt on, yes it was running prior to changing filter and pump
TONISLUG
Are you able to describe the entire process of replacing the manual fuel filter on an 86 chevy suburban.
Sep 7, 2020 at 1:33 PM (Merged)
i assume you mean the gas filter
you need a 13/16 open end wrench and a 5/8 line wrench to remove the lines from the filter.
be carefull of the fuel that will come out. use protection on your hands and saftey glasses.
TONISLUG
I meant fuel pump.
the fuel tank has to be removed to gain acess to the top of the tank so you can remove the pump module.
it is a very involved job as the tank needs to be supported properly so you do not drop it. it is harder if it is full.
you may want to get a shop to do it for you as it is dangerous.
RENEE762
Can anyone tell me wher to find picture instructions on how to change my fuel filter on a 1997 suburban. Either that or detail instructions. Thank you.
JDL
  • 16,098 POSTS
Sorry for the late reply.
The fuel filter should be mounted to inside frame rail, you'll need to get under the vehicle. Usually after the vehicle sits overnight without the key being cycled, there isn't much fuel pressure,but, you still need to be aware. You can disable fuel pump by pulling fuse then try to start the vehicle, to take pressure off system. Slowly take line nuts loose from filter, use a catch pan. Don't let gas hit a droplight. Don't do this in a closed garage or around any pilot lites.
To work on your own vehicles, you need a basic set of wrenches and sockets. I don't remember the actual size wrenches? The picture I posted should show you what the filter looks like.
I realize this an old post. In the future hope you don't have any vehicle issues, but, if do, keep the site in mind. They are always working to improve the site and it's free to ask a question.
Have a good day.
ANOTHERVIEW
  • 20 POSTS
Car is 1997 Suburban 5.7L
I know how to change a fuel filter, and have done so.
I have also changed other things with steel lines and compression fittings such as camshaft driven fuel pumps, brakes, etc.
What I never want to do again is round off the nut holding the line onto--in this case the filter.
I am using a 5/8" line wrench, and it seems like it just does not want to turn. I have sprayed oil on it over some days, now. Different kinds. Today I bought a new can that advertises it is special penetrating oil.
I got to wondering if maybe it was metric. I did the conversion on the computer and 5/8 is between 15mm and 16mm. The 15mm wrench is too big.
Any advice???
CHEVY22
  • 1,375 POSTS
it should be standard and it really depends on what brand of tools you use , i have nothing aginst craftsman but their wrenches spread over time causing this problem, i found this out years ago and bought all snap on and mac tools since and never had that problem again try a good wrench if your not already
good luck
jim
SERVICE WRITER
  • 9,123 POSTS
Try heating it with a torch.
https://www.2carpros.com/forum/automotive_pictures/30961_laughing_3.jpg
Okay maybe not....
Funny seems like sometimes there is a secret size out there that you never have. :roll:
I would go to a vise grip that is larger enough to adequately grab on, get a good bite on the flats, and turn it IN a touch and turn it OUT a touch, and back and forth until you get more and more movement.
There are line wrenches that are valuable
SERVICE WRITER
  • 9,123 POSTS
sorry you said line wrench. :oops:
ANOTHERVIEW
  • 20 POSTS
I said the 15mm was too big. I meant that it was too small.
The 5/8 is a little wiggly (not much, though). My conversion shows 5/8 would be 15.875 mm. So, getting smaller would be 15mm, but that is too small.
I will probably try the vise grip pliers since someone mentioned it.
I had thought of that, but thought people usuially saved that for when the nut was already rounded.
OR, I could chicken out and take it to someone else and hold them responsible--but that seems like a mean thing to do, so I would feel like I would have to disclose why I was taking it to them.
MATHIASO
  • 1,209 POSTS
Hey Paul! I didn't hear from you for a while.
Is everything ok ?
SERVICE WRITER
  • 9,123 POSTS
You can be sure when or if you chicken out that the mechanic will know why.
https://www.2carpros.com/forum/automotive_pictures/30961_skeptical1_4.jpg
And yeah i would save that for when the nut gets rounded, but if you can squeeze it on the flats you might be fine!
SERVICE WRITER
  • 9,123 POSTS
Hey Mat!!!
Everythings is cool,
https://www.2carpros.com/forum/automotive_pictures/30961_fonzi_4.jpg
just taking 2 online upper level courses and have little time here.
https://www.2carpros.com/forum/automotive_pictures/30961_frown_2_3.jpg
Couldn't help out on the one post you sent....
MATHIASO
  • 1,209 POSTS
I will be away for few days.
(I WILL BE BACK )
(Arnold S. The terminator ) :D
