Mechanics
CHEVY IDLES ROUGH AND DIES
2002 Chevrolet Silverado
Engine Performance problem
2002 Chevy Silverado V8 Four Wheel Drive Automatic 80000 miles
My 2002 chevy silverado idles rough on cold start up and sometimes dies. Once driven and warmed up it will run fine.
Bw2410
June 22, 2008.
Inspect and test the coolant temperature sensor and the idle air control valve then report back-
AD
Rasmataz
Jun 22, 2008.
Might want to check the lower intake manifold gasket. Very common on these. Might want to follow this bulletin. Subject: Cold Engine Idle Misfire or DTCs P0171 P0174
Models: 2002-2005 Cadillac Escalade
1999-2005 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe, Trailblazer
1999-2005 GMC Savana, Sierra, Yukon
2003-2005 Hummer H2 99 through 05 GEN III truck engines may experience any of the following: A cold rough idle that diminishes as the engine warms up.
Possible DTCS P0171, P0174, or P0300.
Random misfires at idle. The intake gasket seals may be leaking around the intake ports, causing a lean condition. The intake gasket seals may leak around the bottom side of the port, making it a challenge to detect the vacuum leak. The technician may also notice lower than normal MAF readings if the intake seals are leaking.
If leaking intake gasket seals are found, replace the intake gaskets. During the repair be sure to use the current GMSPO part number for replacement intake gaskets. The current GMSPO part number for intake gaskets will have a teal green intake gasket seal. The old version of the intake gaskets were orange in color. Use only the teal green colored gaskets for a repair.
The intake plenum should also be checked for excessive warpage that may cause an uneven clamping pressure of the seal. If the plenum is found to be warped it will need to be replaced. Service Information states, " An intake manifold with warpage in excess of 3 mm (0.118 in) over a 200 mm (7.87 in) area should be replaced". Intake warpage is measured at the gasket sealing surfaces, and should be measured within a 200 mm (7.87 in) area. This measurement is across only two of the intake runner port openings. Measurements taken across the entire distance of all four intake runner ports will lead to unnecessary manifold replacements.
Let me know what you find.
Brian 1
Jun 22, 2008.
AD
