1998 Chevy S-10 passenger side mirror
1998 CHEVROLET S-10
SHORTY54
1998 Chevy S-10 126k miles
need to replace passenger side mirror, it is not a power mirror. It appears I have to remove door panel. Advice??
Feb 10, 2010 at 11:19 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
a damaged mirror glass face may be replaced by placing a large piece or multiple strips of tape over the glass then breaking the mirror face. Adhesive back mirror faces should be available for most applications. Remove the door trim panel and the water deflector in order to access the mirror retaining nuts. If equipped, remove the access hole plugs, then unfasten the mirror nuts. If equipped, unplug the mirror electrical connection. Remove the mirror assembly from the vehicle. To install: Place the mirror into position and install the retaining nuts. Tighten the nuts to 53 inch lbs. (6 Nm). If equipped, attach the mirror electrical connection. If equipped, install the access hole plugs. Install the water deflector. The water deflector is secured by a strip of adhesive between the deflector and door, as well as waterproof sealing tape. Upon installation, make sure a good seal is achieved to keep water from entering into the body. If necessary, use strip caulking as a sealant between the deflector and door. Install the door trim panel.
https://images.2carpros.com/forum/automotive_pictures/261618_1_115.jpg
DOOR PANEL REMOVAL Remove the door handle bezel-to-door screws and the bezel. If removing the rear door trim panel, unfasten the upper molding screws, then using the trim pad removal tool, separate the molding from the door with the clips still left attached to the molding Unless equipped with power windows, use a window regulator clip removal tool such as J-9886-01 or equivalent, to remove the window regulator clip and separate the handle from the door. Carefully pry off the armrest screw cover and remove the armrest-to-door screw and the armrest. If equipped with power windows, remove/disengage the switch mounting panel. Check the panel for any additional screws and remove then as necessary. Using a suitable trim pad removal tool, remove the nylon fasteners from their seats. Remove the door panel from the vehicle. Installation is the reverse of removal.
Feb 10, 2010 at 2:58 PM
SHADPER
How do you replace a side view power mirror (driver side) on 1994 S10 pickup?
Dec 13, 2016 at 11:03 AM (Merged)
VICK
Shakes or Wobbles problem
1995 Chevy S-10 6 cyl Two Wheel Drive Manual 128,00 miles
How does the door come apart so I can tighten or replace left outside mirror, before it shakes itself off the door. I am especially concerned about how to remove the window crank, and any other info about removing the inside door panel.
Thank you for your time and waiting for an answer.
Vick Fredrick
WATSONSFATHER
Interior problem
1998 Chevy S-10 4 cyl Two Wheel Drive Automatic
besides the door handle screw how do I take off the interior door of a 1998 Chevy s-10 to replace the drivers side mirror
RGMCKINN
1995 Chevy S-10 6 cyl Two Wheel Drive Automatic 150000 miles
How do I replace the passenger side mirror. I have the part but need instructions on how to install
Dec 13, 2016 at 11:04 AM (Merged)
WILBAR66
1995 Chevy S-10
how to change outside passenger mirror
BLACKOP555
  • 10,386 POSTS
you have to remove the door panel and from there you will see bolts behind the door remove them and out will come the mirror. shoudl be 3 of them.
