2CarPros - Car Questions & Answers
1999 Chevrolet S-10 Repair Question
Topics covered: Battery, Fuel pump, Fuse.
Asked on September 9, 2008
1999 Chevy S-10 fuel pump problems
Electrical problem
1999 Chevy S-10 4 cyl Two Wheel Drive Manual 100k+ miles
I have checked all the fuses in the fuse box and they are working fine, but I am only getting 5volts to the fuel pump at the tank. Is there another relay that I need to check? If so where is it and how do I check it? If that is not the problem what is?
Avatar Asked by martini77
Answer
Replied on September 9, 2008
Test the fuel pump relay or swapped it for a known good one its located in underhood fuse block.
Tiny Answered by rasmataz
68 questions asked
Replied on September 10, 2008
swapping out the relay did not resolve the issue. when I turn the key I get 12V to the pump for a brief period, but the pump does not activate. what can I try next.
Tiny Response from martini77
1 question asked
Power the pump direct from the battery and tell me what happened.
68 questions asked
Replied on September 11, 2008
I connected another battery to the pump and it starts working, could it be the connector at the pump?
1 question asked
Could be the connector test it or an open wire on the gray going back to the fuel pump relay.
68 questions asked
Replied on September 15, 2008
Well, I charged the battery replaced the connector at the pump. Using the new splices I checked the voltage at the wires. The combination that powers the fuel pump does not get any voltage to it. All the other combinations of wires get 12v for a second or two when the key is turned on, then all go to zero v except the purple/orange combination which gets 1.27v all the time. what can I try now?
1 question asked
All the other combinations of wires get 12v for a second or two when the key is turned on,this happens bcuz the relay de-energizes
Test the ground wire to the pump-
68 questions asked
Replied on September 16, 2008
Sorry to sound stupid, but I don't have a clue when it comes to auto electronics. How do I check the ground wire to the pump?
thanks
1 question asked
If it comes On then the ground is good.
68 questions asked
Replied on September 17, 2008
With the key on I connected another battery to the connections that power the pump, and it turned on. So that means it is grounded, right? What can I try next? Thanks for the help.
1 question asked
