Does it have a cabin air filter?
BASSMAN_281
  • 2003 CHEVROLET S-10
  • 78,000 MILES
Very little heat comes out floor vents, also seems to smell hot. Thermostat was just replaced
Wednesday, January 25th, 2012 AT 1:15 AM
FIXITMR
  • 9,990 POSTS
No it doesn't have a filter.
Wednesday, January 25th, 2012 AT 4:03 AM
FIXITMR
  • 9,990 POSTS
Is the blower working ok?
Wednesday, January 25th, 2012 AT 4:09 AM
BASSMAN_281
  • 5 POSTS
The blower seems to be working, heat is blowing out of the upper vents
Wednesday, January 25th, 2012 AT 12:57 PM
FIXITMR
  • 9,990 POSTS
Is your temp gauge normal? No fluctuations?
Wednesday, January 25th, 2012 AT 7:29 PM
BASSMAN_281
  • 5 POSTS
Yes, temp is fine no flucuations. Thermostat was just replaced
Thursday, January 26th, 2012 AT 2:56 PM
  • 31,937 POSTS
Did you ensure that the heater was bleed of all air?
Saturday, January 28th, 2012 AT 3:29 AM
FIXITMR
  • 9,990 POSTS
Can you change vent settings and air moves with it?
Saturday, January 28th, 2012 AT 4:07 AM
BASSMAN_281
  • 5 POSTS
Air seems to move only to upper vents, a small amount of air can be felt on lower vents
Sunday, January 29th, 2012 AT 4:24 PM
HOMER1967
  • 875 POSTS
I think you have a blend door issue, I would research that some if I were you.
Sunday, January 29th, 2012 AT 11:53 PM
FIXITMR
  • 9,990 POSTS
Are you saying air flow seems slow out of any vents or just floor?
Monday, January 30th, 2012 AT 7:10 AM
BASSMAN_281
  • 5 POSTS
Just the floor vents
Monday, January 30th, 2012 AT 1:00 PM
KHLOW2008
  • 41,814 POSTS
There was a TSB on such problems. TSB 03-01-38-009, replace the vacuum switch in the transfer case and the HVAC control. Check for any large amounts of oil in the HVAC system.
If the automatic transmission fluid had been changed recently, ensure it is not overfilled.
Monday, January 30th, 2012 AT 1:53 PM
BENSAFE
  • 1998 CHEVROLET S-10
Does this model have a cabin air filter. If sowhere is it located and how do you change it.
Tuesday, April 16th, 2019 AT 1:31 PM (Merged)
HMAC300
  • 48,601 POSTS
Those S-10's do not have cabin filters.
