Mechanics
CHEVY
1998 Chevrolet S-10
Engine Performance problem
1998 Chevy S-10 4 cyl Two Wheel Drive Manual 112500 miles
My engine runs fine. It will not start unless I remove the throttle block air box, open the butterfly flapper and spray starter fluid into the throttle block. It will then start. The vehicle is new to me and seems to start ok if the engine is at normal temperature. The previous owner s tells me it has started hard since it was new.
Ecar9347
May 11, 2010.
SLOW CRANKING SPEED, EXTENDED CRANKING TIME, DTC P1626 TECHNICAL SERVICE BULLETIN Reference Number(s): 87-65-21, Date of Issue: August 13, 1998 Related Ref Number(s): 87-65-21 ARTICLE BEGINNING SUBJECT SLOW CRANKING SPEED, EXTENDED CRANKING TIME, DTC P1626 P1626, HARD STARTING (REPROGRAM PCM) CONDITION SOME OWNERS MAY COMMENT ABOUT INTERMITTENT SLOW CRANKING SPEED AND EXTENDED CRANKING TIME OR MAY DESCRIBE THE CONDITION AS HARD STARTING. SOME OWNERS MAY ALSO COMMENT ABOUT A VEHICLE SECURITY LIGHT THAT STAYS ON THROUGH ONE KEY CYCLE AFTER AN EXTENDED CRANK EVENT. CAUSE THE PCM MAY BE INDUCED TO SYNCHRONIZE INCORRECTLY DURING KEY-UP AND CRANKING. THIS WILL CAUSE SUBSEQUENT IGNITION EVENTS TO BE MIS-TIMED CREATING A SITUATION WHERE THE STARTER IS WORKING AGAINST AN IGNITION EVENT. IF THE VEHICLE IS KEYED DOWN AND ANOTHER STARTING ATTEMPT IS MADE, THE ENGINE MAY START NORMALLY. CORRECTION REPROGRAM THE PCM WITH THE REVISED CALIBRATION THAT TAKES INTO ACCOUNT THE ABOVE CONDITIONS. THESE CALIBRATIONS ARE AVAILABLE ON 1998 CD-ROM 12 AND LATER VERSIONS. SERVICE PROCEDURE 1. IF THE CUSTOMER HAS A CONCERN WITH SLOW CRANKING OR ANY OF THE OTHER CONDITIONS NOTED ABOVE, CONNECT A TECH 2 SCAN TOOL AND NOTE THE CALIBRATION ID CURRENTLY IN THE PCM. 2. REPROGRAM THE PCM WITH THE NEW CALIBRATION NUMBER LISTED IN THE TABLE BELOW. 3. OPERATE THE VEHICLE AND CHECK FOR ANY ADDITIONAL SLOW CRANKING CONCERNS. MODELS: 1998 CHEVROLET AND GMC " S" MODELS 1998 ISUZU HOMBRE WITH 2.2L ENGINE (VIN 4 - RPO LN2)4. IF THE VEHICLE STILL EXHIBITS A SLOW CRANKING CONDITION, USE APPROPRIATE SERVICE MANUAL DIAGNOSTICS TO CORRECT THE CONDITION. CALIBRATION NUMBERS USE THE CORRECT CALIBRATION FROM THE LIST SHOWN IN Fig. 1. Fig. 1: Calibration Numbers Table WARRANTY INFORMATION FOR VEHICLES REPAIRED UNDER WARRANTY, USE: WARRANTY INFORMATION LABOR OPERATION DESCRIPTION LABOR TIME J6355 PROM-REPROGRAMMING 0.4 * DIAGNOSIS TIME MAY BE CLAIMED FOR 0.0 TO 0.3 HOURS DEPENDING ON ACTUAL TIME PERFORMING DIAGNOSIS.
5/11/2010 .
Merlin2021
May 11, 2010.
AD
