2CarPros - Car Questions & Answers
1997 Chevrolet S-10 Repair Question
Topics covered: Transmission, Transfer case, Clutch.
Asked on June 3, 2009
1997 Chevy S-10 slave cylinder
Transmission problem
1997 Chevy S-10 4 cyl Two Wheel Drive Manual 180000 miles
i understabd how to change it from another post but how do i drop the tranny down any info tnx
Avatar Asked by freight_train
Answer
Replied on June 4, 2009
Disconnect negative battery cable. Shift transmission into 3rd or 4th gear. Remove shift lever knob and nut. Remove shift lever retainer screws and retainer (if equipped). Remove shift lever boot mounting screws and boot. Remove shift lever and nut.
Remove exposed bolts on base of housing. DO NOT remove bolts under rubber boot at top of housing. Remove shift lever housing. Raise and support vehicle. Drain transmission fluid. Remove parking brake cable for clearance. Mark drive shaft(s) for reassembly reference. Remove drive shaft(s).
Disconnect electrical connectors from speed sensor and back-up switch. On all models, disconnect exhaust pipe from exhaust manifold. Remove catalytic converter and hanger. If equipped, remove right and left side transfer case-to-transmission braces. On 4WD, place transfer case in 4H position. Remove skid plate. Drain fluid from transfer case. Disconnect vacuum lines and electrical connectors from transfer case (if equipped).
Disconnect shift cable from transfer case. Support transfer case with jack. Remove transfer case-to-transmission mounting bolts. Slide transfer case rearward until free of transmission output shaft. Lower and remove transfer case. Remove and discard gasket. Using Quick Connect Disconnect Tool (J-36221), remove clutch line from concentric slave cylinder quick connect coupling.
Remove clutch housing cover. Remove clutch plate and clutch cover from flywheel. Support transmission. Using a fuel pressure gauge, purge fuel system, and disconnect fuel lines. Remove fuel lines and retainers from rear crossmember. Remove rear crossmember. Move wiring harness away from transmission oil pan.
Lower transmission enough to gain access to top of transmission. Remove wiring harness from front crossmember. Remove engine block ground. Remove transmission mounting bolts as necessary. Pull transmission straight back on clutch hub splines, and remove transmission.
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_174.jpg
Tiny Answered by BMRFIXIT (expert)
19,736 answers provided
Replied on June 11, 2009
very good info thx also if 1 were to take it to a garage what kind of time would be required for this type of repair? im tryin to see if its worth it also its a 2.2l 2wd model.....
Tiny Response from freight_train
1 question asked
4 to 5 hours of labor
plus you have to add parts
good luck
Need a tool or a tester CHECK IT @
http://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Need parts check it @
http://www.eautopartstore.com/
