2CarPros - Car Questions & Answers
1988 Chevrolet S-10 Repair Question
Topics covered: Heater, Control panel, Panel.
Asked on July 2, 2008
1988 Chevy S-10 Vent Control Problem with '88 S10 Chevy Bla
Heater problem
1988 Chevy S-10 6 cyl Four Wheel Drive Automatic 160,00 miles
The heater/AC on my '88 S10 Chevy Blazer blows hot/cold air well. However, when I adjust the selector to any of the AC choices, the air only blows on the floor rather than
the dash vents.
I've checked to see that the 2 vacuum hoses are connected to the heater/AC diaphragm on the floor. Maybe the other ends aren't connected.
Questions
1. Could this be the reason that the baffles don't adjust to bring the air to the dash vents?
2. If so, is there a diagram showing their location on the other side of the firewall?
3. Is there a handy "how to" cheat sheet to disassemble/reassemble the heating/AC system if it turns out that the diaphragm is bad?
My Chilton manual is lacking any information on how to troubleshoot this problem,
Thanks a million,
Jbil
Avatar Asked by jbil
Answer
Replied on July 3, 2008
Does it do the same thing if you select the defrost or dash vents while in heater mode? Do you hear any hissing from the control panel area while in A/C mode?
Tiny Answered by SWilliams
0 questions asked
Replied on July 4, 2008
No hissing sound heard. And air blows to defrost and floor regardless of selection.
Tiny Response from jbil
1 question asked
Ok, Open the hood and look for a vacuum line that runs back to the dash. Follow that line and see if it is split/cracked or disconnected. That line feeds the control panel. It goes to a T in the line that connects to the vacuum reservoir. That reservoir has a check valve in it that may have failed. Follow the other line off the reservoir back to the engine, it will connect to a port on the intake manifold. That is the same line that actuates the 4X4 as well. So check that mess of vacuum lines for a leak as well.
0 questions asked
Replied on July 7, 2008
Thanks for the tip. I'll be checking the line in the next couple days.
1 question asked
