Mechanics
HOW TO REPLACE THE THERMOSTAT ON A 3400
2002 Chevrolet Monte Carlo
My daughters car showed a check engine light after using a diagnostic tool it indicated that the thermostat needs to be replaced. Looking at the V6 3400 engine it does not seem like there is enough room to remove the thermostat without removing the crossovers. My question is am I right in my thinking or is there a way of removing and replacing the thermostat without doing all that work.
Hoppy
February 5, 2007.
You can do it without pulling the crossover, use 1/4 inch sockets and extensions, I do it all of the time
CHEVYII
Feb 19, 2007.
Does the thermostat fit right in and the housing with no problem
AD
Boatfund
Jan 27, 2008.
AD
