Fuel filter
SARATOGAQUILTER
  • 2002 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 100,400 MILES
Where is the fuel filter on a 2002 Monte Carlo
Monday, January 10th, 2011 AT 3:45 PM
DOCFIXIT
  • 18,828 POSTS
Here is a guide to help walk you through the steps of the repair with diagrams to show you on your car below.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Monday, January 10th, 2011 AT 4:36 PM
BAI
  • 1999 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 175,000 MILES
Is my 1999 chevy monte carlo fuel sysem pressurized? I want to change my filter and it warned me to check my system before installing new one. If so how do I depressurize it, so it can be installed.
Tuesday, January 29th, 2019 AT 4:35 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative cable at the battery then loosen the fuel tank filler cap to relieve any fuel tank vapor pressure. Wrap a shop towel around the Schrader valve on the fuel rail and remove the dust cap from the valve. Connect the fuel pressure gauge to the Schrader valve. Install the free end of the gauge bleed hose into an approved gasoline container, and open the gauge bleed valve to relieve the fuel pressure.
C.PAVELKO
  • 1997 CHEVROLET MONTE CARLO
No other details to give.
FIXITMR
  • 9,990 POSTS
Under car by fuel tank.
C.PAVELKO
Thank you for your help.
CAPTUREROFTYME
  • 1996 CHEVROLET MONTE CARLO
Engine problem
1996 Chevy Monte Carlo V6 Two Wheel Drive Automatic 168000 miles
I was coming home last night and my car started acting like it was running out of gas, but it had plenty. I think it's the fuel filter, but I can't find it to check it.
Can someone please tell me where the fuel filter is located on my 96 monte carlo?
Thanks in advance!
DENNYP
  • 1,823 POSTS
Look under the car, along the fuel lines near the fuel tank.
LUISPLACENCIA
  • 1995 CHEVROLET MONTE CARLO
Where is it located, how do I get to it, and how do I repair it/ replace it. Ive worked on cars just not this one very much
Tuesday, January 29th, 2019 AT 4:36 PM (Merged)
THIS IS MIKE
  • 686 POSTS
The fuel filter is under the car, please follow this link https://www.2carpros.com/how_to/how_to_change_fuel_filter.htm thanks for using 2carpros.com
SHELB2514
  • 2005 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 545,000 MILES
Where is the fuel filter located on my vehicle?
RHALL77
  • 3,361 POSTS
If I remember right it is located back of the vehicle just before the gas tank on the drivers side. It a sliver cylinder in the fuel line. If not its on the other side of the fuel tank towards the rear of the car.
JAMES HASTINGS
Engine Mechanical problem
1997 Chevy Monte Carlo 6 cyl Front Wheel Drive Automatic
wher is fuel filter location on fuel injected engine
JDL
  • 16,098 POSTS
My info says it is under the vehicle, by the gas tank. Looks like a threaded fitting on one end and quick connect fitting on the other end. Don't take any lines loose without being sure there is no pressure on the system.
https://www.2carpros.com/forum/automotive_pictures/170934_monte_carlo_fuel_filter_1.jpg
