Heater core replacement?
NONNIE_MARIE
  • 2006 CHEVROLET MALIBU
  • 6 CYL
How to replace a heater core on a 2006 chevy malibu I don't really know the name of some parts so please help me out? Thank you I did take the dashboard out already and the panel with the radio and ac switches etc. And the stuff behind it too. Do I have to remove the silver medal body frame to the car also?
Tuesday, May 20th, 2014 AT 7:21 PM
HMAC300
  • 48,601 POSTS
Here are the instructions on how to replace the heater core and if your car has AC this video will show how to vacuum down and recharge the system.
https://youtu.be/4EqdrBVb0sY
Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
Remove the lower center floor air outlet duct.
Remove the upper center floor air outlet duct screws.
Remove the upper center floor air outlet duct.
Fig. 211: View Of Upper Center Floor Air Outlet Duct And Screws
Drill out the heater core cover heat stakes.
Fig. 212: Removing Heater Core Cover
Remove the heater core cover screws.
Remove the heater core cover.
Fig. 213: Removing Heater Core
Remove the heater core.
the whole heater module has to come out to replace it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Wednesday, May 21st, 2014 AT 3:04 PM
NONNIE_MARIE
  • 11 POSTS
Yeah the first picture that shows the two pieces remove I did that. I'm stuck trying to get to the heater core of picture two
Wednesday, May 21st, 2014 AT 3:16 PM
HMAC300
  • 48,601 POSTS
If the hvac isn't out of the car you are stuck because it's going through the firewall an dthere maybe a screw holding it in. Otherwise check for screws then pry up on it you are going to replac eit anyhow so if you damage who cares. Then you can see what you bent.
Wednesday, May 21st, 2014 AT 3:30 PM
NONNIE_MARIE
  • 11 POSTS
Yes I Think So. Here's Some Pictures Of Where I'm Stuck At
Wednesday, May 21st, 2014 AT 4:04 PM
HMAC300
  • 48,601 POSTS
You are trying to pull it out without having the module out it has to come out so the a/c charge has to be recycled as well. Seepic these are in engine compartment you have to get the module out to get the heater core out.
Wednesday, May 21st, 2014 AT 4:15 PM
NONNIE_MARIE
  • 11 POSTS
Okay that did it got the job done thanks for your help I love this site.
Wednesday, May 21st, 2014 AT 4:37 PM
HMAC300
  • 48,601 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Wednesday, May 21st, 2014 AT 4:38 PM
TERRICOLE
  • 6 CYL
  • FWD
  • 65,000 MILES
How to replace a heater core in a 2006 chev malibu
Tuesday, October 27th, 2020 AT 1:37 PM (Merged)
ERNEST CLARK
  • 1,730 POSTS
Now if you would like to tackle this job anyway, I suggest you purchase a repair manual for your vehicle or subscribe to an on-line service such as "AllData" or "Mitchell 1".
These will give you detailed instructions as well as pictures, a list of hardware/tools required and helpful hints and tips.
The involved process I speak of must begin with the recovering of your a/c refrigerant. This means you have to empty your a/c system of R134a because your "Evaporator" is located in the same place as your "Heater Core", and the removal of the heater core requires the complete removal of your HVAC module assembly, which is located under your dashboard. This will require the removal of your upper dashboard, the a-pillar trim panels, the center console, passenger side kick panel, and a few more small but difficult items.
And all of this must be removed just to get to the HVAC module. Once you have the module removed from the car, there'll be several more pieces connected to the module that'll have to be removed before you can access the heater core.
This is why a shop will quote you an "astronomical" price to service this unit. The mechanics aren't lying to you when the say it'll be "EXPENSIVE"!
Here's the procedure you're looking for. Sorry I can't provide illustrations. (Buy that service manual)
HEATER CORE REPLACEMENT
REMOVAL PROCEDURE
INSTALLATION PROCEDURE
Install the heater core.
Install the heater core cover.
Install the heater core cover screws. Tighten Tighten the screws to 1.5 N.M (13 lb in).
Install the upper center floor air outlet duct.
Install the upper center floor air outlet duct screws. Tighten Tighten the screws to 1.5 N.M (13 lb in).
Install the lower center floor air outlet duct.
Install the HVAC module assembly.
ROBBIE R SHORE
  • 5 POSTS
  • 2005 CHEVROLET MALIBU
  • 3.5L
  • V6
  • 170,000 MILES
Is the housing mounted to the fire wall from the engine compartment?
HARRY P
  • 2,292 POSTS
Well Alldata and Prodemand make no specific mention of whether or not there are any bolts on the firewall that hold the HVAC or core in place, but it is entirely possible that there are some. I have seen it a few times. Of course the heater hoses are running up to the firewall, so they need to be taken off and can kind of hold things in place, almost like a nut or bolt would.
You will need to discharge the air conditioner when doing this job.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Here are some diagrams on how to do the job.
ROBBIE R SHORE
  • 5 POSTS
So I have completed the heater core and put everything back together, but now I have no power steering and it only blows cold air. Any ideas on what I did wrong?
HARRY P
  • 2,292 POSTS
You might check the fluid and such. And make sure that the steering and various column pieces are all tight, and that there is nothing interfering with the wheel's movement down under the dash.
As for the cold air, you probably left the blend door actuator unhooked/unplugged. Or maybe the control unit needs to be reset and go through the relearning process. Try disconnecting the battery for ten minutes and then reconnect it. Start the car, turn the heat on, and wait a few minutes. See how it feels then.
Also, be sure that you completely refilled the cooling system and got all of the air bled out of it. Because when you took to core out, a lot of air got into the system.
ROBBIE R SHORE
  • 5 POSTS
Okay, I will try to reset it. Because I could hear something when I adjusted the air temperature and I opened the bleeder and added about 1.25 gallons of antifreeze. But the relearning thing makes sense. Thank you
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,305 POSTS
Did you disconnect the steering column when you did the heater core removing the dash?
Tuesday, October 27th, 2020 AT 1:38 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
  • 90,000 MILES
How to remove and replace the heater core
  • 52,797 POSTS
REMOVAL PROCEDURE
Remove the HVAC module assembly. See: Housing Assembly HVAC Service and Repair
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten
Tighten
Huge job for at home
ROBBIE R SHORE
  • 5 POSTS
I did n I connect a wires b4 I bolted steel bracing to firewall but I disconnected it to tighten bolts. So that was my problem easy fix just forgot to plug back in. And reseting the battery for my heat also fixed it. So now its running and all is well thank you very much for ur help. Amd if ever I have another issue ill b back to this site
HARRY P
  • 2,292 POSTS
Hey that's great to see! Please do come back any time you need to. And send your friends too.
ROBBIE R SHORE
  • 5 POSTS
I will indeed
