Location for the power windows? Windows not working
2001 CHEVROLET MALIBU
15,000 MILES
RICHARD67
All 4 of my windows just stopped working. Checked and seen no fuse for the windows, assume they are controlled by a relay or circuit breaker. Dont have a car manual, so not sure the location to look and find either of the two. Windows not working can someone please help me out?
Mar 23, 2012 at 4:55 AM
FIXITMR
  • CAR REPAIR CONTRIBUTOR
  • 9,990 POSTS
Here is a guide to help you test for power and the breaker and the fuse and breaker locations below with the wiring diagrams so you can see how the system works.
This guide can help as well
https://www.2carpros.com/articles/electric-window-repair
Mar 23, 2012 at 6:22 AM
BRETT_GILBERT
  • 0 POST
I had this problem and replaced the main control switch for $98.00 all fixed! I love this site.
Jan 29, 2019 at 2:21 PM
CHEVETERAN
my window will not go up or down. all u here is a click like the motor is lock or the switch isn't working.
Jan 29, 2019 at 2:21 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
May need to pull the panal of and get a look inside, window regulator may be bad or the motor may be bad by sounds of it. Hot wire the motor and see if it works once the panal is off.
CHEVETERAN
the window finally rolled up. it might have a shortage or something is trying to go out?
SERVICE WRITER
  • 9,123 POSTS
IT may be a binding regulator, short in the motor, wiring or switch is what I would expect.
VSHIELDS
posible cause for power window not working
MERLIN2021
  • 17,250 POSTS
You need to test the switch, and the motor, test the motor by removing the trim panel, unplug the motor connector, activate the switch, in both directions while testing the leads with a volt meter, or test light. If the light comes on, the problem is the motor, if not the wiring or switch is bad. Replace motor this way.
https://www.2carpros.com/how_to/power_window.htm
RHOP
the power windows on the left side are not working there is power to the switch and i havent gotten to taking the door off but knows something about these that would save me alot of work
Jan 29, 2019 at 2:22 PM (Merged)
  • 110,190 POSTS
Hi:
Without checking, my first guess would be the main switch on the driver's door. Check for power to the rear motor and front. Let me know if there is power. If there isn't, replace the switch.
KRABDI
Computer problem
1998 Chevy Malibu 6 cyl Automatic
Two of my power windows do not work at all. One of these windows will not stay closed. It slips down constantly even when the car is still. Until I can get the car repaired, what do I do in the meantime to keep it closed? Thank you.
MASTERTECHTIM
  • 4,750 POSTS
duct tape is what i always use around the top of window frame.
PCORT166
MY FRONT DRIVERS SIDE WINDOW WILL NOT GO UP,.HOW CAN I CLOSE IT?
SERVICE WRITER
  • 9,123 POSTS
IF there is any portion of the window exposed, pull up while holding the button to raise it, pound on the panel to try to jar it and you may get lucky.
If not pull the panel and see what is going on inside. Have seen a lot of regulators go bad on these.
Once the panel is off you can better see what to do. If money is an issue you can raise the glass and block it with a piece of wood.
BILL97
Electrical problem
2000 Chevy Malibu 6 cyl Front Wheel Drive Automatic
driver side window failed in the down position. the up side of the switch feels soft when pressed to raise window. I suspect a switch problem.
Can I jump around the controls and get the window in the up position while I wait for a new switch?
Can I supply 12v to the motor and make it raise the window? There are 2 wires to the motor.
RHALL77
  • 3,361 POSTS
yes you should be able to jump the wires to get the window up. most dealers have the switch in stock other wise go to the local junk yard
DENISEZANE
I have power windows. I lowered my drivers side window and now it will not go back up, it will however continue to go down. All the other windows go up and down. The passenger side front window will not open using the button on the drivers door, only the passenger can lower it with their button. Any ideas what it may be? How can I get the wondow up right now, it is pouring rain outside of course.
SCOTTY DEE
  • 592 POSTS
Okay, no big deal. The window regulator in the drivers door has gone south forever. you will need a new regulator and I believe they are a regulator & motor assembly.
Let me know if you have questions!
Scotty
DENISEZANE
so until I can replace the regulator and or motor will I be able to manually put the window up if I remove the door panel? Since the window works as far as going down perhaps it's not the motor?
SCOTTY DEE
  • 592 POSTS
Unitl you fix the window just leave it up. I'm sure your motor is fine, but the regulators are made with the motors built onto them.
CRAZYG
Electrical problem
the window on passenger side will not go up all other windows work. is it possible its just the switch,it will go down but not up.I'm sorry i could not donate anything but i am financialy unfit.Thank you
Jan 13, 2020 at 9:15 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Take switch from rear door switch if it works switch bad. If not motor bad.
Motor on this site go to car replacement parts go to AutoParts Warehouse. Price the best anywhere.
@$30 to $50 parst house $110+
