Mechanics
CHEVY ADVICE
1999 Chevrolet Malibu
Engine Mechanical problem
1999 Chevy Malibu 6 cyl Front Wheel Drive Automatic 59.000 miles
my car leaks oil and antifreeze
Susan827
February 28, 2009.
HI there,
You will need to locate these leaks, wash down the engine and run and watch for fresh oil leaking, check front seal rear seal, rocker cover oil filter and oil pressure switch as these are the most likely cause, as for the coolant, get a cooling system pressure test as this will locate any external coolant leaks easily.
Mark (mhpautos)
Mhpautos
Mar 1, 2009.
