heater blows cold air
2007 CHEVROLET IMPALA
GAMBLER66
The heater will blow cold air even when temp gauge is at halfway point. As soon as you drive the car it starts to heat up and work fine. Started at first to do it once in a while nows seems to be more frequent. I have checked antifreeze all fluids are fine and cap is tight no visible leakage.
Thanks
Dec 15, 2009 at 7:41 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,354 POSTS
This sounds like you have a problem with the blend door actuator for the temperature. Here is a guide to help you see what I am talking about.
Here is the location for your car (below)
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Feb 12, 2018 at 2:27 PM
PAINT
  • 0 POST
yep that did the trick for me.
RAIDER4EVR
Heater problem
2007 Chevy Impala Automatic
My family got this car fairly new last year. Last winter, we had an issue where the heater would stop blowing hot air when the car would come to a stop or be idling. We took it in to the dealer, they said they checked it and there were no problems. When we got in, the heater worked fine. This year, actually a few days ago, we noticed the same thing starting. Heater will only blow cold air until we are moving. At stop lights and when idling, it goes back to cold from hot. Any ideas? I'm thinking it was something loose that the techs touched last time and fixed and maybe has come loose again, but i'm no genius with cars..... Any help would be appreciated. TY
Jan 13, 2020 at 6:40 PM (Merged)
RHALL77
  • 3,361 POSTS
or it could be a possible short in the wiring or a possible HVAC controller going bad. do you have auto matic temp controls
TERRY_N1
My heater blows cold on my 3.9L V6 at idle even though the engine temp is mid-range. As soon as I rev the engine to 2000-3000 rpm, the air blows hot. When I let it idle down, the air cools off.
Any ideas?
Terry_n1
DENNYP
  • 1,824 POSTS
You need to have the air bled from the cooling system.
NORMMONUS
I remote start the vehicle which is pre-propgrammed to run for 10 minutes. During this cycle, there is very little to no noticeable warmth going to the windshield to defrost on cold days. The fan blows full as required (automatically). Only when I physically key start the vehicle do I get warmth.
KEVIN12881
  • 336 POSTS
I have the same problem with my 06. When you start the car, I do not have remote start, and leave it in park it will not get verry warm. As soon as i start moving, or get the RPMs over 1.2k it gets hot, even when i stop at a light I notice it gets cool again. These cars just do not have great heaters and they do not register the need for heat at idle.
BRIAN 1
  • 1,030 POSTS
I"ve had alot of these vehicles do this,they have air in the cooling sys.try this bleeding procedure:Poor heat at idle, however, if the engine RPMs are raised the concern no longer occurs.
Recommendation/Instructions:
Note: Be sure to follow all SI safety procedures and caution notices.
With the engine cooled off, remove the coolant pressure cap.
Remove upper heater core hose from the metal pipe on the engine.
Add coolant to the metal pipe, until full.
Raise the rubber portion of the heater core hose as high as it will go with it still attached at the heater core. Using a funnel, add coolant until the hose is full.
Reconnect the heater core hose.
Start engine, have assistant raise the RPMs to about 1500 to 1700 RPMs, top coolant off at engine, then before lowering engine RPMs, install the coolant pressure cap.
Fill coolant reservoir as necessary, then check the heat at idle.
Note: If the vehicle returns for the same complaint perform the cooling system draining and refilling procedure
see if this makes a difference,post back with any other questions.
BRANSCOS
MY heater in my car is not blowing out hot air. The only time it does is when i give it gas when idiling or when the car is moving. Then the heat is great!! The rest of the time it just blows cool air. What can I do to fix this??
BRIAN 1
  • 1,030 POSTS
try bleeding the coolant sys,Poor heat at idle, however, if the engine RPMs are raised the concern no longer occurs.With the engine cooled off, remove the coolant pressure cap.
Note: If there is still a lack of heat at idle, perform the cooling system draining and refilling procedure
post back with what you find
LEROYJM
No heat when idling. Heats up when driving, cools when stopped.
HMAC300
  • 48,601 POSTS
check coolant level first thenif low add and then have pressure checked for leak.
KITTYCATHY
My parents have a 2007 impala that not get warm until like a half hour. When we start the car it is freezing cold and wont get warm until it is on the highway. It also gets cold at idle. My dad checked the coolant and it was extremely low and that seemed to fix the problem. The coolant is slowly leaking though? Do you know what could be causing this? Any help would be appreciated Thank you
DOCFIXIT
  • 18,828 POSTS
Yes low coolant level will cause heating loss. If leak is not external then likely intake manifold gasket or cylinder headgasket fault.
Try replacing the thermostat and see what happens
GLORIA73
No circulation of water when i open the radiator, i do not see any water leaks, sometimes it needs water but not a lot most of the times its full. the water seems like its going through the block to radiator their is no blockage. I will drive it two blocks the most and it will be on the half mark on the temperature gauge but water would be boiling when i open radiator cap. the heater and air conditioner just stopped today but over heating started 2 weeks ago. also car has been parked 8 months prior from me buying it 3 weeks ago.
HMAC300
  • 48,601 POSTS
this may be a thermostat or head gasket problem have it pressure checked for leaks as it may be leaking between block and head. and have thermostat checked as that may be the problem as well.
