Headlight blinking on and off
2005 CHEVROLET EQUINOX
102,500 MILES • 3.4L • 5 CYL • AWD • AUTOMATIC
WBF21
Changed driver side headlight, which is now very dim and no high beam, and now the passenger side headlight flashes on and off. Looks like morse code.
May 3, 2015 at 8:18 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Please check the grounds fist but it sounds like you blow a fuse on the BCM. Is it a stock headlight set up? Here is a guide to elp you check the fuses and the fuse location along with the headlight wiring diagrams so you can see how they system works.
Check out the diagrams (Below). Please let us know what you find. Cheers
May 3, 2015 at 8:30 PM
WBF21
Thank You for your answer, but I did check the ground and the other wires and connection points. That car has never done this before, and I bought it brand new in Dec. 2004. So I checked the BCM fuses and found one blown replaced it and know it all works! Thanks :)
May 5, 2015 at 2:36 AM
  • 110,190 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
May 6, 2015 at 6:41 PM
JIMJMIII
At one time I had the drivers side low beam headlight go out. I replaced the buld and it worked for about two hours. Then the pass side went out replaced the bulb and it worked. At the time to check headlights the drivers side went out. I can not keep replacing the bulbs. Is there a way to get a wiring diagram to trace wires to try to find the problem. Thank you in advance. Jim
Dec 19, 2018 at 1:50 PM (Merged)
JIMJMIII
Found the trouble to the drivers headlight low not working. There must have been a repair to replace the socket for the headlight, because one of the splices came apart.Repair the splice and now the headlight works.
