2006 Chevrolet Colorado Repair Question
Asked on April 30, 2008
Chevy check engine light error code p0014
Engine Performance problem
2006 Chevy Colorado 4 cyl Two Wheel Drive Automatic 79000 miles
Just had light come on and code read as P0014. Definition of this is a cam phasing error. Explanation is "The ECM has detected the camshaft phase angle has exceeded its tolerance value". I have my list of probable causes but wanted to know if these are popping up for Chevy's and if so what is the usual problem? Is it a sensor or something else mechanical? I have had no problems with the engine, everything sounds and runs fine, can I still saefly drive it? Just had mechanic look it over a week ago and give it the thumbs up on everything is fine.
Answer
Replied on June 11, 2008
remove the cam phaser solenoid valve and check the screens for a restriction. This code usually comes up on vehicles that don't get regular oil changes.
