changing the Starter
2004 CHEVROLET COLORADO
MIKE_92R
How do i change my starter on my truck?
May 25, 2008 at 12:55 PM
DENNYP
  • CAR REPAIR CONTRIBUTOR
  • 1,824 POSTS
Here is a guide that will walk you through the steps of replacing the start with diagrams and instructions below to show you how on your truck.
Jun 11, 2008 at 11:02 PM
NICK LANDRY
Engine Mechanical problem
2004 Chevy Colorado Two Wheel Drive Automatic 67892 miles
im trying to replace the starter on my truck . it has a 3.5 in line 5 cyl an i cant figure how to reach the other bolt on the starter . i cant see it but theres two 15mm bolts an it s in a bad spot and dont want to take anything off i wouldnt have to...
Feb 5, 2019 at 6:19 PM (Merged)
  • 110,190 POSTS
THey are a pain. You will need to work from top and bottom to remove iit. Also, see if you can gain access through the inner finder.
