HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cobalt
Engine Cooling
Thermostat
SPONSORED LINKS
Thermostat location
DANIELUSALAZAR
MEMBER
2005 CHEVROLET COBALT
4 CYL
2WD
AUTOMATIC
130,000 MILES
How to replace the thermostat, and where is located it?
Sunday, October 11th, 2009 AT 11:52 AM
BLUELIGHTNIN6
MECHANIC
The thermostat is located near the bottom radiator hose. Here is a guide to help you see step by step and diagram below to show you the locations:
Cheers
Images (Click to make bigger)
SPONSORED LINKS
Sunday, October 11th, 2009 AT 10:49 PM
ROD GALE
MEMBER
1 POST
4 CYL
FWD
MANUAL
174,000 MILES
Where is the thermostat located? I cannot seem to find it.
Thursday, August 2nd, 2018 AT 5:51 PM (Merged)
DOCFIXIT
MECHANIC
See a pipe coming off back of water pump? At the end of pipe see two bolts that is thermo housing. Remove and there is thermostat.
Please
login
or
register
to post a reply.
Related Thermostat Content
Thermostat
How Do I Change The Thermostat On My 2009 Chevy Cobalt? Ac Stopped Working And The Engine Light Came On. Autozone Says The Engine Light Was...
Asked by
hawk1252
2 IMAGES
2009
CHEVROLET COBALT
VIDEO
Thermostat Replacement Chevrolet Blazer
Instructional repair video
GUIDE
Thermostat
The thermostat is located on the engine either at the inlet or outlet radiator hose connections and is part of the cooling system, this unit is designed to stop the flow of...
2005 Chevrolet Cobalt Overheating And Coolant Leak?
I Am Having Problems With My Cobalt. I Was Recently In Traffic With My Ac On. My Coolant Temperature Reached 230 Degrees When My Car Started...
Asked by
Ronnie21
1 ANSWER
2005
CHEVROLET COBALT
Coolant Temperature Sensor
Engine Cooling Problem 4 Cyl Front Wheel Drive Automatic I Have A 2007 Chevy Cobalt Ls With A 2.2 Liter Ecotec Engine, I Am Having...
Asked by
Samms21
6 IMAGES
2007
CHEVROLET COBALT
Radiator Fan
The Radiator Fan Has Three Wires. I Know It Is A Two Speed Fan. If The Fan Is Going To Run On High, Which Of The Three Wires Is Negative...
Asked by
mochto
1 ANSWER
1 IMAGE
2006
CHEVROLET COBALT
2007 Chevrolet Cobalt Coolant Leak
My Car Was Heating Up So I Had To Get The Water Pump And Radiator Fixed, Brand New Parts. Even After All That It's Still Running Hot And...
Asked by
ac1234
1 ANSWER
2007
CHEVROLET COBALT
VIEW MORE
SPONSORED LINKS
How to Replace Thermostat
Thermostat Replacement Mercedes Benz C230
Thermostat Replacement Ford
Online car repair manuals
