how much for fuel pump and normal time to install?
1998 CHEVROLET BLAZER
SARAH HURD
i was wondering how much for fuel pump and normal time to install for a garage.
Dec 28, 2009 at 6:07 PM
SQM
  • CAR REPAIR CONTRIBUTOR
  • 6,383 POSTS
In order to replace the fuel pump, the fuel tank needs to be removed, as the pump is located inside the tank.
Here is a helpful guide:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Those fuel pumps can cost between $80.00 to $140.00 depending on the brand.
As for the installation it will vary as each shop has different labor rates.
It is always a good idea to call a few shops to choose the best option.
I have attached diagrams for the fuel pump replacement procedure below for your reference.
Dec 8, 2021 at 9:35 AM
MICHELEY
Other Category problem
1998 Chevy Blazer 220000 miles
I am a smart woman but realistically am I going to be able to do this myself? Or should I be calling mechanics now?
Oct 28, 2024 at 5:55 PM (Merged)
MERLIN2021
  • 17,250 POSTS
Do you have about 400-500? If you havn't been involved with this sort of job before, get some help...
  • 54,350 POSTS
Yep, you need to drop the fuel tank, to replace the pump here is a video to help you see how the job is done that way you can tell if this is something you want to do.
https://www.youtube.com/watch?v=bCcueO4ALxQ
Let us know if you need anything else.
AJINBLAZERLUV
1st , Is a Fuel Pump considered a Lubricating Part on an Engine .
2nd , when having a fuel Pump replaced Filter was replaced ( by my Request ) is there anything else I need to be aware of in case the shop forget s something ...?
WRENCHTECH
  • 20,761 POSTS
A fuel pump is lubricated by the fuel in the tank that it's submerged in but I wouldn't consider it in a category of "lubricated parts" although I would bet that there is some warranty company trying to do that.
The filter is probably the only other thing to deal with at the time but have him make the the electrical plugs have good tight contacts. GM has a lot of problems with them.
AJINBLAZERLUV
Thanks! I will have regular Maintenance done this week with oil change I will have them do as you suggest ... much appreciated !
CLANE923
Engine Performance problem
1998 Chevy Blazer 6 cyl Four Wheel Drive Automatic
My 98 blazer will start and run for about 20 minutes. Once it gets hot it will shut off. Whether that has anything to do with it shutting off or not is beyond me. when it shuts off the fuel pump seems to make a different noise than when it starts. fuel pump was replaced last year along with the filter. Fuel is in the tank at 1/2. It will not restart immediately but if I wait 5 minutes or so no problem....vroom. Now it will only run for about 1 minute.
RHALL77
  • 3,361 POSTS
is there a check engine light on, did you check fuel pressure
CLANE923
no check engine light. do not have a pressure gauge. guess i need one huh...??
ASHLEYWILLI
Engine Mechanical problem
1998 Chevy Blazer 4 cyl Two Wheel Drive Automatic
How do i change the fuel pump and drop the gas tank on my Chevy Blazer??
  • 110,190 POSTS
Make sue the fuel tank is as close to empty as you can get it. Disconnect the battery, remove the mounting straps from the tank and the tank will drop down and out. I would suggest using a floor jack to lower the tank. It could be heavy. The fuel pump is on the top with one large retaining clip holding it in. Remove the clip and the pump comes out.
If you have other questions, let me know.
