SRX Radio
BEAU ANTES
  • 2007 CADILLAC SRX
  • 1.4L
  • V6
  • AWD
  • 160,000 MILES
I was in the car and the sound went off there is no door chime. I can't access the fuse box under the drivers side to pull the amp fuse the seat won't tilt up. I disconnected the cable on the battery that did not work. I'm not sure where the amp is in the back of the car other than on the drivers side. How much of that rear panels I have to remove?
Thanks Tommy Ps I figure the seat issue later!
Monday, January 19th, 2015 AT 4:15 PM
CADIEMAN
  • 3,544 POSTS
You should check the radio, RSA/RSE, and AMP fuses first here is a guide to help you check for power.
Here are the fuse locations and the locations of the radio components with the wiring diagrams so you can see how the system works. Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Monday, January 19th, 2015 AT 8:55 PM
PAULA777
  • 0 POST
Thank you for this post after a ton of testing I had to replace the amp. FYI cost me $100.00 for a used one.
Monday, October 22nd, 2018 AT 2:35 PM
DAVE SRX
  • 2005 CADILLAC SRX
  • 6 CYL
  • AWD
  • 117,000 MILES
i have a 2005 srx cadillac and the radio died last nite (complete black out) I checked the fuse and its ok.
Any thoughts what this could be?
Monday, October 22nd, 2018 AT 2:36 PM (Merged)
FACTORYJACK
  • 4,159 POSTS
Is there any audio from the speakers. The first thing to do, would be to disconnect the battery cables and short them together. This will reboot the vehicle, and perhaps correct the condition.
IMICON
  • 2005 CADILLAC SRX
  • 6 CYL
  • AWD
  • 45,000 MILES
Our 2005 cadillac srx suddenly lost all sound from the radio. It turns on, seeks, scans, and switches from radio mode to cd mode but no sound. Any suggestions?
FACTORYJACK
  • 4,159 POSTS
The only thing that comes to mind, right off hand, is possible logic lock of the amp. Does the door chime function? You can try removing power to the radio and amp via the left rear fuse block. It is under the rear seat cushion, at the front, under the carpet. The fuses are AUDIO and AMP. Or try disconnecting the battery cables, touching them together for a minute or so, and reconnecting them.
TAHOEN4U
Have you found a fix to this issue yet? I have the same problem.
Thanks
Tony
FACTORYJACK
  • 4,159 POSTS
I did not receive any reply on whether this brought the radio back, I did receive some votes so I have to assume it may have worked.
JDURAN66
Disconnected the battery cables on my 2009 srx and the radio came back.
Thanks!
ECBROOME
  • 2004 CADILLAC SRX
  • V8
  • AWD
  • 50,000 MILES
Had car inspected today and serviceman said he had to jump the car to get it started (not sure why-battery seemed good when I dropped it off). As a result, when I left the shop, the radio/navigation screen is dead. Will not respond to any buttons.
FACTORYJACK
  • 4,159 POSTS
Take both cables loose and short them together for about a minute, and reconnect. Often times jump starting will create a logic lock condition in various modules, and can be reset be discharging the capacitors, which is accomplished by shorting the battery cables together.
Monday, October 22nd, 2018 AT 2:37 PM (Merged)
ECBROOME
This did the trick. Thanks for the quick response, my wife can't go wothout a radio.
JOE WEATHERMAN
  • 2012 CADILLAC SRX
  • 6 CYL
  • AWD
  • 120,000 MILES
I cannot figure out how to adjust the volume to the rear seat speakers.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,305 POSTS
It should be in the radio balance and fade adjustment, do you have the manual for the car?
Best, Ken
STEVE W.
  • 13,038 POSTS
Try pushing the tone button, then fader, then press and hold the menu/select button down until the number changes to 0. That will reset the fader to center.
To adjust it to a different number just rotate the menu knob and push the button once to set.
Does this vehicle have the rear seat DVD infotainment option? If so that option has rear seat headphones that use their own controls. If you hold the stereos power button on for 3 seconds it will turn off the rear option and enable the "normal" speakers.
BRADUNDER
  • 2006 CADILLAC SRX
  • 6 CYL
  • AWD
  • 85,000 MILES
Hi, my dvd player would not work, no power, any suggestions?
FACTORYJACK
  • 4,159 POSTS
Did this just all of a sudden occur, or was it after a power loss, or jump start? First thing I always try, is disconnecting the battery cables, and touching them together. If it is a logic lock condition, this can often clear it.
ANGBA1
  • 2006 CADILLAC SRX
  • 6 CYL
  • 66,700 MILES
My husband purchased XM radio for my car and I love it but I cannot get it to display the song titles and artists as it does in his STS. If my car is XM ready shouldn't I be able to have this information displayed? Will I have to take it to a dealer for assistance?
FACTORYJACK
  • 4,159 POSTS
Is it an aftermarket type of system, with a remote keypad? If it is, then it was just integrated into the vehicles sound system, and any display issues are respective to the unit itself.
TVHUET
  • 2005 CADILLAC SRX
  • 4 CYL
  • AWD
  • 69,500 MILES
My Cadillac SRX has noise in the AM radio stations. Any ideas?
