Cylinder location and firing order
JENIMAE
  • 1998 CADILLAC DEVILLE
need firing order in relation to cylinder
Thanks
Tuesday, December 2nd, 2008 AT 9:40 AM
  • 108,320 POSTS
Hi:
I hope this helps. It for a Deville 4.6L.
https://www.2carpros.com/forum/automotive_pictures/249084_94652368_1.gif
If you have other questions, let me know.
Friday, December 5th, 2008 AT 10:49 PM
STORMY747
  • 1995 CADILLAC DEVILLE
  • V8
  • FWD
  • 120,000 MILES
Where do you start #1 from the engine to the distributer cap? Do it go clockwise or counterclockwise? Is it possibe to show a diagram of the firing order for the selected make and model?
Tuesday, February 12th, 2019 AT 5:03 PM (Merged)
BUZZSAW
  • 1,198 POSTS
The firing order is on the intake, I believe it goes in a clocewise direction, remove the distributor cap to ck, to find where #1 is remove the #1 plug and have someone bump it over when its on #1 compression should be comming up
EDB40505
  • 1990 CADILLAC DEVILLE
Engine Mechanical problem
1990 Cadillac Deville V8 Front Wheel Drive Automatic
I need to now the firing order for a 1990 Cadillac Deville. I found one diagram
https://www.2carpros.com/forum/automotive_pictures/512618_55492DE_1.jpg
But this doesn't seem to be correct.
https://www.2carpros.com/forum/automotive_pictures/12900_fo_105.jpg
BRGORDON
  • V8
  • FWD
  • 135,000 MILES
I need to see a diagram showing the firing order and distributor wiring. Thank you for your help.
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2851.jpg
JAMES1990PERRY
  • 1991 CADILLAC DEVILLE
1991 Cadillac Deville V8 Front Wheel Drive Automatic
I need to know the firing order for my 1991 Cadillac DeVille V8 engine. What oder should the spark plugs be to/for the Distributor cap?
https://www.2carpros.com/forum/automotive_pictures/12900_fo_99.jpg
