2005 Buick Rendezvous engine cutting out
2005 BUICK RENDEZVOUS
61,000 MILES • 6 CYL • AWD • AUTOMATIC
SLWIN489
we replaced the fuel pump and filter and the intake valve and it still cuts out. What can we do
Sep 7, 2009 at 4:07 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Can you describe what actually happens? Does the car restart, does it die all at once? Has the check engine light come on?
Here are a few guides to read, they will help you figure this out
https://www.2carpros.com/articles/stall-at-idle
https://www.2carpros.com/articles/engine-stalls
Dec 8, 2009 at 1:32 PM
E W
We have an '05 Buick Rendezvous. My wife is the regular driver. She had started telling me that she smelled gas when her car was near full, then the gas hand stopped working regularly. After you fill the tank, it works okay until you are around a 1/2 tank then it goes haywire. 2 weeks ago, she went to leave the house in the morning, and she could not get it started. It just kept turning over. I went out and told her she might flood it. I waited a few minutes and while keeping the pedal pressed to the floor was able to get the car started, put it in gear, eased off the gas to back out and it cut out. Cranked it the same way again, and rode the brake pedal and gas together, eased it out and drove down the street and around the block. As long as I kept my foot on the gas it wouldn't cut off. We had it towed to our mechanic shop. It worked perfectly for him from the time it came off the truck, never cut off. He went ahead and replaced the fuel filter. It worked fine for the next 1.5 weeks & then the same thing occured again, 3 mornings ago. Before I pour more money down in it or on a fuel pump, I wanted to get some other ideas, i.e. - oxygen sensor or some kind of relay that might have affected it like this.
Thanks,
EW
Jul 28, 2019 at 11:39 AM (Merged)
Check the fuel pressure if its within specs if okay-clean out the idle air control valve and EGR valve and test the throttle position sensor and manifold absolute pressure sensor.
EBLEAS
Car will pretty consistently do the following when started first thing in the morning. The engine starts, acts like it is trying to run, grumbles a bit (or a lot) and then dies out after a second or two. Usually starting it again will cause it to start and run. This only happens after letting the car sit overnight. Starts during the day after the initial start are usually fine. Once running, the car runs great - no hesitation, stalling or other issues. No codes displayed when scanned, no warning lights displayed. Here is what has been replaced by me or a shop recently (either for this issue or another problem):
- Fuel pump / filter (shop)
- Crankshaft position sensor (shop)
- PCM (me)
- Ignition switch (me)
After I replaced the PCM (to correct a crank / no start condition), I did not do the crankshaft relearn procedure which is recommended, as I don't have the Tech II scanner needed. Is this important? What would be common things to look for next? I read the fuel pressure regulator can have a slow leak which causes gas to accumulate which results in a too-rich condition when first started. Any help to guide me in what to try next would be most appreciated.
  • 54,354 POSTS
From the symptoms you have disclosed, it sounds like you have a slow to react at start up IAC idle air control valve. Can you remove it and clean all ports and the motor, also clean the throttle body. Let see what you find, please get back to us.
Here is a link to help see what needs to be done,
Thanks for the donation!
NMART
car just stalls out and than restarts, i replaced mass air flow sensor recently.
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner
NMART
Thanks I going to change out iac valve because the idle seams very low at times low as 600 rpm to 800 hope this helps.
HMAC300
  • 48,601 POSTS
try cleaning it first you may not need the new part. the plate gets sticky and causes the uneven idle.
