Mechanics
THERMOSTAT REPLACEMENT
2002 Buick Rendezvous
Engine Cooling problem
2002 Buick Rendezvous 6 cyl All Wheel Drive Automatic 105000 miles
Need to replace the thermostat on my 2002 Buick Rendezvous. I would like to know what I need to remove and how to remove it so as to have access to the the two thermostat housing bolts?
Paleoman
April 18, 2010.
Remove the air cleaner and duct assembly.
Drain the coolant until the coolant level is below the thermostat.
Remove the crossover exhaust pipe.
Remove the radiator hose from the thermostat housing.
Remove the thermostat housing bolts and clean any sealer from the bolt threads.
Remove the thermostat housing and gasket.
Remove the thermostat.
Clean the mating surfaces.
http://www.2carpros.com/forum/automotive_pictures/261618_1_156.jpg
http://www.2carpros.com/forum/automotive_pictures/261618_2_104.jpg
Install the thermostat.
Install the thermostat housing and gasket.
Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm).
Install the radiator hose to the thermostat housing.
Install the crossover exhaust pipe.
Install the air cleaner and duct assembly.
Fill the cooling system.
Bluelightnin6
Apr 25, 2010.
AD
