Stuck on "check tire pressure"
Checked tire pressure, ok
Pushing DIC buttons will not change reading
Saturday, October 29th, 2011 AT 11:59 PM
FIXITMR
MECHANIC
Did you try pressing and holding reset button for 5 or more seconds?
SPONSORED LINKS
Sunday, October 30th, 2011 AT 4:21 AM
PETE1940
MEMBER
I've tried holding, 5 seconds, and more, but the DIC, does not respond at all. When key is on, the area for mileage and information, says "check tire pressure", pushing reset button, or any other one, on the panel, does nothing.
Sunday, October 30th, 2011 AT 10:03 AM
FIXITMR
MECHANIC
Do you have owners manual for car? Did you find reset instructions in there and follow them?
Monday, October 31st, 2011 AT 1:02 PM
PETE1940
MEMBER
I've tried all ideas. Is this panel, hard to remove, or replace?
Monday, October 31st, 2011 AT 4:55 PM
PETE1940
MEMBER
1999 BUICK PARK AVENUE
99,935 MILES
Had tires checked, pressure ok.
Pushing buttons will change, reading.
SPONSORED LINKS
Monday, January 6th, 2020 AT 4:31 PM
(Merged)
FIXITMR
MECHANIC
Hey pete, this post says pushin buttons does something?
(Merged)
PETE1940
MEMBER
Forgot, to put "doesn, t change" in there.
At, 71 years old, I, slip sometimes.
I don't have, a repair manual, only owners manual.
(Merged)
FIXITMR
MECHANIC
I'm not far behind ya at 65 and I slip alot already!
(Merged)
HOCKEYMOM14
MEMBER
1 POST
I also have this problem. My car will switch between "check tire pressue", "engine coolant low" and "change engine oil soon". Tire pressure is not low, engine coolant is not low and I just had oil changed 800 miles ago. Is there a way to reset the driver information center?
(Merged)
SGIES1
MEMBER
1 POST
1998 BUICK PARK AVENUE
6 CYL
FWD
AUTOMATIC
80,000 MILES
Getting erronious information on the gauges. Also gas gauge does not work. Needle on back side of peg.
Check engine fluid light on, but fluid is ok as well as temp. I've been told it might be some type of module that needs to be replaced.
(Merged)
MECHANIC
Have you had the computer scanned for trouble codes? Most parts stores will do it for free. You can reset the gas gauge with a strong magnet. Just use it outside the plastic and " grab" it with the magnet and pull it back.
