turn signal flasher
1998 BUICK PARK AVENUE
127,111 MILES • 6 CYL • FWD • AUTOMATIC
TRINNIN
my turn signals do not work but my hazerd lights do,i changed my turn signal switch and checked my fuses so now i think its the relay.but i cannot locate the relay in any of the fuse boxes and its not visiable under the dash where should i look for this modol.
Mar 23, 2008 at 1:26 PM
  • CAR REPAIR CONTRIBUTOR
The turn signal flasher is located behind the dash right of steering column carrier
See the guide below on testing the wiring
The wiring diagrams and flasher location are attached below
Mar 23, 2008 at 1:34 PM
DAVIDDANSKER
how do I access turn signal flasher module on 2001 Park Avenue Buick? have taken nearly all dashboard parts off, can't get to it under or over. Have new part, know what it looks like, cant see it.
Oct 23, 2018 at 6:10 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
located right of steering column near hold bracket
ROY SAVASTA
David, to access the flasher, remove the stop light switch and cruise control brake switch, pull down the plastic cover that surrounds the three wire connectors directly behind the brake switch. Next, pull down the two black plastic blocks that the three wire connectors are plugged into. The flasher, believe it or not, is above these two blocks. Lots of luck
CADIEMAN
  • 3,544 POSTS
there is a clip on the right side of the column like doc said its round with yollow rings on it.
91BPA
The turn signal lights on my 1991 Buick Park Avenue do not work. I believe I need to replace the turn signal flasher (relay), but I cannot locate it. Can you tell me precisely where the flasher (relay) is located? (I've seen some "hints," i.e., under the dash, driver's side, etc., but I need to know EXACTLY where it is located, please.)
  • 54,369 POSTS
The turn signal flasher is located under the dash on the drivers side here is a diagram of the location. It is tucked by the drivers kick panel.
Check out the diagram (Below)
Cheers
2CP-ARCHIVES
  • 4,540 POSTS
Where is the blinker flasher located
under left side of dash between the steering column and the center
ANGIE1665
i need to find the location of the flasher so my blinkers will work
Its behind dash on left side of steering column brace sorry no pic location.
CW_JEFFRIES
I have the same issue as some others...driver-side and 4-way flashers work great, passenger-side flasher does not work at all.
If this is a flasher unit problem, how do I get to it?
Thanks!
Try checking it-its located behind dash right of steering column carrier
WIZARD071
do have a blow up & instructions on how to remove the turn signal module on this buick. Also how to remove & replace the turn signal switch. The turn signal will not flash on the right side but will flash on the left side , also the 4 ways flash ok. Thanks
REPS4BPAV
I am having the exact same problem. left turning works but right does not. Bulbs are okay - emergency flasher works and lights come on with light switch(parking and headlights).
Can anyone tell me how to get to the signal flasher switch under the instrument panel? I read that the flasher switch could be the problem.
KELLY STAMM
I think I did this backwards.....I donated $20 thru PayPal before I registered to ask a question....not sure my donation will show up now.
I recently acquired a '99 Buick Park Avenue 2nd hand and I absolutely love its performance and the immaculate leather interior; I am just frustrated with having no turn signals.
Within 48 hrs. of getting the car, we noticed that the LEFT signal wouldn't flash; just stayed on constant. And when we'd park the car and turn the ignition off, the left turn lights stayed on solid which would have run the battery down had we not pulled the fuse under the hood, passenger side.
We inspected the bulbs/lamps. All seemed to be good, but we didn't change them. Reading a couple of posts on this sight makes me wonder if that would help.
What we did do was acquire a used turn signal assembly from a salvage yard, installed it and all seemed to work. Within 24 hrs. it was doing the same thing again.....we assume it has burned up these 2 turn signal assemblies.
I love this car and my husband is saying "trade it off" and so is my son, but I want to get another opinion before I give it up.
Thank you for your help! Kelly Stamm
Check the turn signal flasher its behind the dash right of steering column carrier.
TERRIBLESWEDE3
My turn signal flasher was running slower and slower, then stopped completly. Should I and how do I replace the flasher?
Michael in KC
BLUELIGHTNIN6
  • 16,542 POSTS
the flasher is most likely at faulty, yes. it is replaced by disconnecting it from it's wiring connector and installing new one. the flasher is located on the left kick panel.
ASHLEYMCCOY
The tail lights, left signal lights, and interior lights on my 1999 buick park avenue don't work. What may be the problem?
KHLOW2008
  • 41,814 POSTS
Start by checking for blown fuses.
ASHLEYMCCOY
I've checked the fuses. There fine.
KHLOW2008
  • 41,814 POSTS
By interior lights do you mean the dash and other illuminations? Does it include the courtesy and dome lights?
For the left turn signals, do any of exterior bulbs lights up or none at all? Does turning on the hazard lights make them work?
For the fuses, apart from underhood there is one fuse block under the dash.
All these are linked to the Lamp Control Module, behind left side of dash, right of steering column.
ASHLEYMCCOY
The lights on the dash, like were the speed is don't work. My brake lights work and my right side turn signal and hazard lights work. But only the brake lights work on the left side. But the tail lights don't work period.
KHLOW2008
  • 41,814 POSTS
For the stop lights, check the bulb. Test for battery voltage to the Light Blue wire. This wire is linked to each othere between right and left.
Dash illuminations and taillights shares the same circuit and gets its power supply from the Lamp Control Module (LCM). Test the LCM Brown wire for battery voltage when taillights are turned on.
If all lights works correctly when hazard lights are turned on, the left not working could be due to a faulty turn signal switch.
