driver side a/c flows warm air, passenger side flows cold air?
2003 BUICK PARK AVENUE
B TYSON
Why does the driver side a/c flows warm air, passenger side flows cold air, why?
Jul 12, 2010 at 10:49 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Could be a stuck temperature blend door on the driver's side here is a guide to help see whats going on.
Jan 9, 2019 at 10:58 AM
VILLIE
i get heat on the passenger side but cold air on the driver side?
Jul 8, 2020 at 10:34 AM (Merged)
DAVE H
  • 13,384 POSTS
You have a blend door actuator that is not working for the passengers side which is common. Here is a guide to help walk you through the repair with diagrams below to help you do the repair on your car.
TMAJKA
Thank you for this post I love this site.
DSG1966
I have dual climate control. This winter no matter how high I turned the tempature to the passanger side always pushed out cold air. It does it no matter if it is on Auto or I have the settings set manually, cold air comes out of the vents, floor, defrost.
Thanks for your help
BMRFIXIT
  • 19,053 POSTS
Suspect bad blend door actuator
inside HVAC box
BPWEIBEL
I have a 1997 Park Ave that blows out hot/warm air on the driver's side and ice cold air on the passenger's side. What could be causing this?
HMAC300
  • 48,601 POSTS
check to see i f your actuators are getting power and working. i've enclosed a pic to show what they look like. it's not your car but it'sclose so you'll get the idea.
Jul 8, 2020 at 10:35 AM (Merged)
BPWEIBEL
I have checked these as best I could and they appear to be working. They do move from floor to dash to defrost as they are supposed to. I'm having trouble understanding the air flow and how 1 fan could give 2 independent air streams (driver’s compartment and passenger compartment/back seat) that could be different temps. Reading the owners manual, the suspect the passenger dual air temp control is involved. There must be something to adjust the temp independently but I haven't figured out where to check this. Can you help? Thanks.
HMAC300
  • 48,601 POSTS
if they are working they will either be getting power or not. if they are getting power then your actuator is bad, if they aren't then tne control unit is sending the signal. try pullling the fuse for about 3o-60 seconds and it may reset.. if not have apro check it out.
RAYMOND24
Computer problem
1997 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
the air blows good. only on one side. i have the climate control where passenger can change thier own temperature. the driver side blows hot. ask people about it and they say that there is a arm that opens up to split the air. is there any way that i can look for myself. or would i have to take it to a shop
  • 110,190 POSTS
Hi:
Yes, there is a blend door that directs the air flow in different directions. It sounds like there is a problem with it. You can try looking under the dask to locate it; however, you will most likely need to remove several parts to see it. I suggest taking it to a mechanic unless you are confident enough to try it yourself.
Let me know what you decide.
POLKAHOLIC
what would cause hot air to blow out on the drivers side and only cold on the passenger side?
BLUELIGHTNIN6
  • 16,542 POSTS
A likely cause for this make and model is the weakening and subsequent crimping of one or more of the vacuum lines, or softened connector nipples within the A/C programmer. Check your connectors and vacuum lines for any defaults and post your results. I will follow up.
POLKAHOLIC
thanks for the response while checking the vac lines ect behind the glove box i was adjusting all of the settings to try and figure out what devise activates with each setting. when i turned the temp setting to the lowest setting then back up to the highest i had heat on both sides of the car again. I was able to change the settings to all positions and the heat remained on both sides. I put the dash back together and when i tested it again i started out with heat then i heard the sound of the vac line and it switched back to cold air on the passenger side again. I changed the temp to the lowest setting and after i heard the devise complete its rotation i turned the temp back up and the heat is on both sides again. I know i havent fixed the problem but hopefully this will continue to work until i do find the solution.
FORD33
You are on the right track. with the glove compartment out. Look on top of the heater box there is an arm about 2" long; it is located approx. behind where the left corner of the glove box would be. This arm attaches to a "not sure if it's a" vacume/ electric motor. The arm is splined and will strip out; causing it to work intermittently till it doesent work at all. I simply disconected the arm from the rod and installed a spring to hold it one way for summer and the other winter.
Hope this helps. Bruce
CHRISTINARCLARK
Hello.
A/C compressor is good and working. Recently recharged and hose replaced. Please suggest issue. Thank you.
Jul 8, 2020 at 10:36 AM (Merged)
  • 54,354 POSTS
This sounds like the blend door actuator for the drivers side is out. here is a guide to help walk you through the repair and instruction with the location of the blend door actuator for you car in the diagrams below:
Remove or Disconnect
- The actuators are specifically designed for the right and left side of the heater and A/C module. When servicing an actuator, be sure to replace it with the correct service for the position being serviced.
1. Sound insulator(s) as required to gain access to actuators.
2. Knee bolster, console, trim as required.
3. Electrical connector from actuator.
4. Screws retaining actuator.
5. Actuator.
Install or Connect
1. Actuator with mounting screws.
Tighten
- Screws to 1.4 N.m (12 lb. in.).
2. Electrical connector.
3. Knee bolster, console, trim.
4. Sound insulator(s).
Important
- After the actuator has been replaced, the actuator needs to be re-calibrated for proper travel. The ignition must be cycled ON for 3 minutes to allow the programmer and the actuators to re-calibrate for proper travel.
This shows the passengers side unit so the drivers side should be near the gas pedal. Check out the diagrams (below). Please let us know what happens.
MKMOORE
The passenger side climate control delivers hot air when the air conditioner is on. The slide lever indicates that it is on cool but it really is not
  • 110,190 POSTS
Check the blend door for that side. I believe the actuator is under the steering column.
