1990 Buick Lesabre Repair Question
Topics covered: Cooling fan, Cooling fan relay, Engine.
Asked on May 17, 2010
1990 Buick Lesabre Radiator Cooling fan relays
Engine Cooling problem
1990 Buick Lesabre 6 cyl Front Wheel Drive Automatic 101,00 miles
What is the location of the cooling fan relays. The fan doesn't come on and I was told to check the relays.
Answer
Replied on May 18, 2010
If you turn on the ac does the fan run? Some systems, if you use a jumper wire at the datalink connector to access mil codes, the fan will run.
The relays should be under the hood, driver-side front.
