Fuel pump relay location?
2003 BUICK CENTURY
180,000 MILES
J.STIEG
  • 361 POSTS
has no power at Fuel pump relay. The relay coil has power and comes on. There does not seem to be any power supply for the pump to run at the relay. I can supply fuel pump with voltage from the battery and fuel pump comes on.
Jul 9, 2012 at 5:00 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
you'll have to check to see if there is a bad connection at the computer or relay not letting it go on. It's a dark green wire with a white stripe. also check the ground wire, it connects to the trans stud.
Jul 9, 2012 at 7:15 PM
J.STIEG
  • 361 POSTS
I'm saying that the relay coil is powered and comes on without a problem.
Problem is with the main feed coming into the relay.
Can you post a diagram? thanks
Jul 9, 2012 at 7:32 PM
HMAC300
  • 48,601 POSTS
here is the diagram. hope you have checked the fuse underhood, it's #35 if the pcm doesn't send a signal to the relay though it won't come on either.
Jul 9, 2012 at 7:36 PM
VNVET68-222
Electrical problem
2002 Buick Century 6 cyl Front Wheel Drive Automatic
car will not start, can use jump wire on fuel pump relay and it will start and run, what would cause the relay not to operate the fuel pump
Mar 30, 2019 at 12:05 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
the relay being bad itself, bad fuse, also check wiring to pump and relay.
OGYVER
Car won't start, in fact died on the freeway. Towed it home and found I had spark. Disconnected the fuel lines at rail, tried to start car, no fuel came out either of the the lines. Fuel pump relay clicks so it is functioning. I took the fuel pump access plate off and the electrical connector at fuel pump only registers 5 volts when ignition or starter is on. Is this the correct voltage? If not what else in the circuit is dropping the voltage? Thanks.
Nov 26, 2020 at 10:26 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
clicking relay does nt mean its supplying the power it means the trigger circuit is working. Here is a guide to help check the relay and the fuel pump relay location #19 in the diagrams below
Check out the diagrams (Below). Please run this test and get back to us.
I am attaching an illustration of where this is located. Please reach out to us if you need more info. Thanks for visiting 2CarPros.
H. MARTIN
where is the fuel relay located and which one is it
INTERNETMECHANIC
  • 700 POSTS
Under the hood, passenger side front, #3. Also, to be sure, compare wiring colors at relay connector.
https://images.2carpros.com/forum/automotive_pictures/512072_century_fuel_pump_relay_1.jpg
https://images.2carpros.com/forum/automotive_pictures/512072_buick_century_2_1.jpg
JJAROS8400
  • 9 POSTS
I have looked for the relay compartment under my hood, on the passenger side up behind the head light, but I cannot seem to locate it. Please help!
Here is a guide and the location of the fuel pump relay and fuse which is right next to the relay.:
Cheers
My 94 Buick Century died. Has spark so and starts briefly when I spray Starting Fluid through the air intake. The voltage at the fuel pump is plus or minus 9 volts so I suspect the fuel pump relay may be faulty. On March 26th "bluelightnin6" posted a diagram showing the location of the AC Compressor Clutch Relay but the diagram isn't a large enough file to enlarge and read where the Fuel Pump relay is located. Can someone post a larger file or offer any suggestions on what I should be looking for besides the relay.
Nov 26, 2020 at 10:27 AM (Merged)
TWOSTEPPER
  • 42 POSTS
Use a gauge, check fuel pressure. Use a noid light to check for injector pulse. It shows an oil pressure switch in the fuel pump circuit. If the switch is functional and has voltage, once you crank it enough to bring up oil pressure, the switch closes. The pump will run, even with the relay unplugged. If multiple relays close to each other, look at the color of wires at the connector.
https://images.2carpros.com/forum/automotive_pictures/510352_century_fuel_pump_relay_1.jpg
EAZBEA
Where is fuel pump relay? Also reset switch?
CARADIODOC
  • 34,309 POSTS
"Inertia switches" are a Ford thing.
WENDY28
Engine Mechanical problem
1991 Buick Century 6 cyl Front Wheel Drive Automatic
WHERE IS IT LOCATED?
JDL
  • 16,098 POSTS
welcome to the forum. The relay should be under the hood, passenger side front, relay pack. If your not sure which one it is, look at the wire colors at the connector. 3.3L engine
https://images.2carpros.com/forum/automotive_pictures/170934_buick_century_33_1.jpg
BRUSSELL29
where is my fuel pump relay located?
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. It is located on the right hand front of the engine compartment. Here is a tutorial showing how to test a relay:
I've attached a picture below of its location on your vehicle. Hope this helps and thanks for using 2CarPros.
2CP-ARCHIVES
  • 4,540 POSTS
1989 Buick Century mileage: 100,000. My car was running fine! Then without warning it quit & wouldn't start again! My question is where is the fuel pump relay fuse located? I can't find it in any manual?
2CP-ARCHIVES
  • 4,540 POSTS
The fuel pump relay is located on a bracket on the right front corner of the engine compartment. A 12-volt test light will verify whether or not power is getting to the relay. Some fuses are not marked in the fuse box. Check all the fuses with the 12-volt test light.
JDL
  • 16,098 POSTS
Click on the link, fuse is C4
