Vacuum hose diagram
QUINCIE88
  • 2000 FORD CONTOUR
  • 14,456 MILES
I need a vacuum hose diagram for 2000 ford contour 2.0 engine It also has rough idling and when driving it on and off I have to drive with 2 feet?
Monday, October 24th, 2011 AT 6:18 PM
Here is the diagrams you have requested the engine vacuum line routing. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Wednesday, October 26th, 2011 AT 10:19 PM
LUDGAIL
  • 1998 FORD CONTOUR
  • 4 CYL
  • FWD
  • 160,000 MILES
I somehow managed to break the vacuum hose coming off the brake power booster. I can't find the place it connects to. Any help would be appreciated.
Thank You
Monday, January 13th, 2020 AT 9:20 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
The vacuum line goes to the intake manifold near the rear. Here is a vacuum routing diagram so you can see.
Cheers
LUDGAIL
Thank you for the diagram, but I still can't tell where the vacuum line off the power booster goes to. I don't see any places around or under the intake to connect to.
SATURNTECH9
  • 30,870 POSTS
There is only one port big enough for the brake booster hose. Look toward the rear of the intake manifold.
DATKIDQ
  • 1999 FORD CONTOUR
  • 2.0L
  • 4 CYL
  • FWD
  • 153,230 MILES
My power booster vacuum hose came off and I don't know where it goes back at. Not off the brake booster itself but wherever it connects too. Can you help me out and also if you have a diagram can you forward it to me please. Thank You.
HMAC300
  • 48,601 POSTS
We dont' really have a diagram this is about as close to get to it. It shold be a fairly large pipe same size as hose on intake manifold.
TRUCKIE07
  • 1998 FORD CONTOUR
  • 120 MILES
Need an engine vacuum line diagram for a 1998 ford contour gl
Here is the engine vacuum line diagrams for both 4 and 6 cylinder engines.
Cheers
2CP-ARCHIVES
  • 4,542 POSTS
  • 1996 FORD CONTOUR
  • 134,000 MILES
Where does the brake booster vacuum line connect to the intake, mine is broke at that end and I dont know where it goes.
CARADIODOC
  • 33,752 POSTS
Look under the hood for the emissions sticker. It will show that hose. You will also have a real noticeable vacuum leak that should be easy to locate. Ford used to use a big black plastic vacuum tee in the middle of the firewall. Here is a diagram below.
Cheers
