blower fan only works on the high position?
2000 TOYOTA CAMRY
AXMAN1
My blower fan only works on the high position. what could it be? If it is a relay, where would it be located at?
Jan 30, 2008 at 7:12 PM
SQM
  • CAR REPAIR CONTRIBUTOR
  • 6,383 POSTS
Sounds like you have an issue with the blower motor resistor.
The resistor is what controls the fan speed. Many times, when the resistor fails, it will only blow in one speed, typically in the highest setting.
The blower motor resistor is located on the blower motor housing. To access it you will have to remove the glove box.
Here is a helpful article:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Oct 12, 2021 at 11:17 AM
