Car cranks but will not start
2002 ACURA RSX
123,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SAVAGE420
  • 7 POSTS
Fuel pump and fuses are good and there is gas in it. Help!
Nov 13, 2018 at 12:45 PM
JONNYB1963
  • CAR REPAIR CONTRIBUTOR
  • 263 POSTS
Hi there,
Do me a favor and go to this link:
Run down the list of things there and let me know if you need anything more after going running through the list of things.
Jon
Nov 13, 2018 at 1:36 PM
  • 54,354 POSTS
Will it run with starting fluid? Also, can you hear the pump run in the tank key on not cranking the engine over? It could be a crankshaft sensor. When they go bad they don't leave a code. Go over the guide JONNYB1963 suggested to start. Here is the crankshaft sensor location and a guide to help you through the steps:
Cheers, Ken
Nov 13, 2018 at 3:16 PM
SAVAGE420
  • 7 POSTS
Yes, I can hear the fuel pump humming when my man turns the key to the on position. Have not tried starting fluid yet but will give that a try.
Nov 13, 2018 at 4:55 PM
  • 54,354 POSTS
Nov 14, 2018 at 10:20 AM
SAVAGE420
  • 7 POSTS
I most definitely will. I have a feeling it may be the fuel pressure regulator or the crankshaft positioning sensor. Gonna get some starter fluid today and give that a shot. Will post my results.
Nov 14, 2018 at 11:28 AM
SAVAGE420
  • 7 POSTS
So our buddy came and looked at it and it is the fuel pump. Thanks for all the advice. Got it started with some starter fluid.
Nov 14, 2018 at 9:09 PM
  • 54,354 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Nov 15, 2018 at 10:57 AM
BULLETPROOF
my rsx turn over but wont start
Nov 15, 2018 at 10:58 AM (Merged)
Go to this link: https://www.2carpros.com/articles/car-cranks-but-wont-start
SAVAGE420
  • 7 POSTS
One other question, what would cause the brake light to stay on?
Nov 15, 2018 at 7:35 PM
  • 54,354 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Nov 16, 2018 at 1:22 PM
